If you run the watchtower, it will be updated automatically and you would not have any problems.
Please, stop and remove the storagenode container and run it back with all your parameters.
2020-12-07T22{SEMICOLON}36{SEMICOLON}49{DOT}761Z ERROR trust Failed to fetch URLs from source {“source”{SEMICOLON} “{URL_REMOVED}”, “error”{SEMICOLON} “HTTP source{SEMICOLON} Get "{URL_REMOVED}"{SEMICOLON} x509{SEMICOLON} certificate signed by unknown authority”, “errorVerbose”{SEMICOLON} “HTTP source{SEMICOLON} Get "{URL_REMOVED}"{SEMICOLON} x509{SEMICOLON} certificate signed by unknown authority\n\t{STORJDOTIO}{FORWARDSLASH}storj{FORWARDSLASH}storagenode{FORWARDSLASH}trust{DOT}(*HTTPSource){DOT}FetchEntries{SEMICOLON}63\n\t{STORJDOTIO}{FORWARDSLASH}storj{FORWARDSLASH}storagenode{FORWARDSLASH}trust{DOT}(*List){DOT}fetchEntries{SEMICOLON}90\n\t{STORJDOTIO}{FORWARDSLASH}storj{FORWARDSLASH}storagenode{FORWARDSLASH}trust{DOT}(*List){DOT}FetchURLs{SEMICOLON}49\n\t{STORJDOTIO}{FORWARDSLASH}storj{FORWARDSLASH}storagenode{FORWARDSLASH}trust{DOT}(Pool){DOT}fetchURLs{SEMICOLON}240\n\t{STORJDOTIO}{FORWARDSLASH}storj{FORWARDSLASH}storagenode{FORWARDSLASH}trust{DOT}(Pool){DOT}Refresh{SEMICOLON}177\n\t{STORJDOTIO}{FORWARDSLASH}storj{FORWARDSLASH}storagenode{DOT}(Peer){DOT}Run{SEMICOLON}781\n\tmain{DOT}cmdRun{SEMICOLON}210\n\t{STORJDOTIO}{FORWARDSLASH}private{FORWARDSLASH}process{DOT}cleanup{DOT}func1{DOT}4{SEMICOLON}362\n\t{STORJDOTIO}{FORWARDSLASH}private{FORWARDSLASH}process{DOT}cleanup{DOT}func1{SEMICOLON}380\n\tgithub{DOT}com{FORWARDSLASH}spf13{FORWARDSLASH}cobra{DOT}(Command){DOT}execute{SEMICOLON}842\n\tgithub{DOT}com{FORWARDSLASH}spf13{FORWARDSLASH}cobra{DOT}(Command){DOT}ExecuteC{SEMICOLON}950\n\tgithub{DOT}com{FORWARDSLASH}spf13{FORWARDSLASH}cobra{DOT}(Command){DOT}Execute{SEMICOLON}887\n\t{STORJDOTIO}{FORWARDSLASH}private{FORWARDSLASH}process{DOT}ExecWithCustomConfig{SEMICOLON}88\n\t{STORJDOTIO}{FORWARDSLASH}private{FORWARDSLASH}process{DOT}ExecCustomDebug{SEMICOLON}70\n\tmain{DOT}main{SEMICOLON}338\n\truntime{DOT}main{SEMICOLON}204"}
Error{SEMICOLON} trust{SEMICOLON} failed to fetch from source “{URL_REMOVED}”{SEMICOLON} HTTP source{SEMICOLON} Get “{URL_REMOVED}”{SEMICOLON} x509{SEMICOLON} certificate signed by unknown authority
2020-12-07T22{SEMICOLON}36{SEMICOLON}52{DOT}178Z INFO Configuration loaded {“Location”{SEMICOLON} “{FORWARDSLASH}app{FORWARDSLASH}config{FORWARDSLASH}config{DOT}yaml”}
2020-12-07T22{SEMICOLON}36{SEMICOLON}52{DOT}194Z INFO Operator email {“Address”{SEMICOLON} ""}
2020-12-07T22{SEMICOLON}36{SEMICOLON}52{DOT}194Z INFO Operator wallet {“Address”{SEMICOLON} "”}
Even tried with another identity that I revalidated (thanks for busting my CPU to fix your bugs btw).
PS: Thanks for limiting new users to 2 new links, making it impossible to post my logs properly… Hope you can decode this…
michal@O2-storj:~$ sudo -s docker pull storjlabs/storagenode
Using default tag: latest
latest: Pulling from storjlabs/storagenode
Digest: sha256:97cff527a277ab7ac6f02f8be547f1087c9677db3bcfce476fcd1e97e99b1622
Status: Image is up to date for storjlabs/storagenode:latest docker.io/storjlabs/storagenode:latest
this is new node on ubuntu 20.10 on Raspberry pi 4
I assume you mean the output of wget -O - (otherwise you will not see anything).
docker run -it --rm --entrypoint /bin/sh storjlabs/storagenode -c “wget -O - https://tardigrade.io/trusted-satellites”
Connecting to tardigrade.io (104.198.14.52:443)
writing to stdout
12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S@us-central-1.tardigrade.io:7777
12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs@europe-west-1.tardigrade.io:7777
121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6@asia-east-1.tardigrade.io:7777
1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE@saltlake.tardigrade.io:7777
12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB@europe-north-1.tardigrade.io:7777
100% |****************************************************************************************************************************************************************************************************************************************************************************************************************************| 417 0:00:00 ETA
No aggression here. I have been running storj nodes since V2 and it is hard enough to make money without these bugs that cause downtime and make us lose money through no fault of our own.
I am happy storj will be paying 2X this month, but this does not excuse the attitude that consists in penalizing operators that have downtime caused by them (believe me, I know what I am talking about).
And here I thought you were on board since v2 and you know what you’re talking about…
If you don’t care about egress, then your 24h of downtime have absolutely zero effect on your earnings… (and at the moment DQ or suspension for downtime isn’t even active… and you’d currently need 288h to reach suspension. so what’s the problem with 24 hours of downtime if egress isn’t your concern?)
unfortunately unsuccessful - thank you very much for support, i am quitting my ARM device tryouts , no problem i ll stay on my regular ubuntu and windows nodes
