X509: certificate signed by unknown authority for https://tardigrade.io/trusted-satellites
Hi, it looks like the newest docker image (IMAGE ID = ba7e12155ec9) does not have the CA required for https://tardigrade.io/trusted-satellites. Symptoms:
From a log file of a restarted node:
2020-12-05T15:31:40.798Z        FATAL   Unrecoverable error     {"error": "trust: failed to fetch from source \"https://tardigrade.io/trusted-satellites\": HTTP source: Get \"https://tardigrade.io/trusted-satellites\": x509: certificate signed by unknown authority", "errorVerbose": "trust: failed to fetch from source \"https://tardigrade.io/trusted-satellites\": HTTP source: Get \"https://tardigrade.io/trusted-satellites\": x509: certificate signed by unknown authority\n\tstorj.io/storj/storagenode/trust.(*List).fetchEntries:96\n\tstorj.io/storj/storagenode/trust.(*List).FetchURLs:49\n\tstorj.io/storj/storagenode/trust.(*Pool).fetchURLs:240\n\tstorj.io/storj/storagenode/trust.(*Pool).Refresh:177\n\tstorj.io/storj/storagenode.(*Peer).Run:781\n\tmain.cmdRun:210\n\tstorj.io/private/process.cleanup.func1.4:362\n\tstorj.io/private/process.cleanup.func1:380\n\tgithub.com/spf13/cobra.(*Command).execute:842\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:950\n\tgithub.com/spf13/cobra.(*Command).Execute:887\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.ExecCustomDebug:70\n\tmain.main:338\n\truntime.main:204"}
From a container of a node I did not restart yet:
root@x:~# docker exec -it d0653897873a sh
/app # wget https://tardigrade.io/trusted-satellites
Connecting to tardigrade.io (104.198.14.52:443)
ssl_client: tardigrade.io: certificate verification failed: unable to get local issuer certificate
wget: error getting response: Connection reset by peer
/app #
I’ll let engineering know, thank you
@ToyooCan you please let me know which tag this corresponds to and additionally which arch?
latest x86 at least
PS C:\Users\aaleo> docker run -it --rm --entrypoint /bin/sh storjlabs/storagenode
The arm is affected too
pi@raspberrypi:~ $ docker run -it --rm --entrypoint /bin/sh storjlabs/storagenode
/app #
alpine:latest working fine
$ docker run -it --rm alpine wget https://tardigrade.io/trusted-satellites
saving to 'trusted-satellites'
trusted-satellites   100% |************************************************************************|   417  0:00:00 ETA
'trusted-satellites' saved
storjlabs/storagenode:latest, amd64
I just downloaded it, installed curl and checked it. That seems to find the correct CA.
I’ll see what the alpine container is missing.
@Toyoo I pushed images that should be fixed here:
Can you test them please?
Seems fine, the node works now. Thank you!
I just pushed the updated sets to our main repo. This hopefully fixes it.
Thanks for reporting and keeping an eye out!
amazing fast time to resolution! thank you @stefanbenten for the quick action, and thanks to @Toyoo and everyone else onthread for helping us improve
I agree, I couldn’t imagine a better response from Storj!
Did my docker nodes restart 12h ago because of this or do I need to check?
Edit: I checked
time=“2020-12-05T17:19:09Z” level=info msg=“Found new storjlabs/storagenode:latest image (sha256:cbeccde9e35acbe3ec35a21e3a68529c96fe01627a1982dd4921ce9674473ab2)”
I am not sure I like getting updates without a version number update
Yes it’s updated to the same version at the moment with a new certificates to do not fail during any restart.
Yes, my nodes just restarted and kept the same version number.
Very off-putting :slight_smile:
So you prefer that it will be in infinity restart cycle on any restart without this update?
I don’t think so :slight_smile:
Ideally I would have preferred a different version number, but really it makes no difference as such.
I was just puzzled by all my nodes restarting for no obvious reason, that’s all.
Hi I am new here, 2 months old as a storagenode operator. I am using Rock64 running ubuntu 18.04 bionic minimal 64bit. Everything was working well until few days ago my OS crashed. I am switching to armbian focal now, re-installed docker and copied my backup storagenode identity to my config path. However, when I start the docker, these errors show up in my log.
How should I troubleshoot this?
Hello @dseah,
Stop the storagenode, remove the container, then execute
docker pull storjlabs/storagenode
And run your node with all your parameters again.
Hello, I tried to pull latest image, but doesn’t help…
2020-12-07T21:56:42.908Z INFO Configuration loaded {“Location”: “/app/config/config.yaml”}
2020-12-07T21:56:42.914Z INFO Operator email {“Address”: “XXXXXXX”}
2020-12-07T21:56:42.914Z INFO Operator wallet {“Address”: “XXXXXXX”}
2020-12-07T21:56:43.943Z INFO Telemetry enabled {“instance ID”: “1iPV9F3GHWqyXBmaUVfhnADNBpYJ9UmxYrckstmXhdNCjyz9pH”}
2020-12-07T21:56:44.351Z INFO db.migration Database Version {“version”: 46}
2020-12-07T21:56:45.545Z ERROR trust Failed to fetch URLs from source {“source”: “https://tardigrade.io/trusted-satellites”, “error”: “HTTP source: Get “https://tardigrade.io/trusted-satellites”: x509: certificate signed by unknown authority”, “errorVerbose”: “HTTP source: Get “https://tardigrade.io/trusted-satellites”: x509: certificate signed by unknown authority\n\tstorj.io/storj/storagenode/trust.(*HTTPSource).FetchEntries:63\n\tstorj.io/storj/storagenode/trust.(*List).fetchEntries:90\n\tstorj.io/storj/storagenode/trust.(*List).FetchURLs:49\n\tstorj.io/storj/storagenode/trust.(*Pool).fetchURLs:240\n\tstorj.io/storj/storagenode/trust.(*Pool).Refresh:177\n\tstorj.io/storj/storagenode.(*Peer).Run:781\n\tmain.cmdRun:210\n\tstorj.io/private/process.cleanup.func1.4:362\n\tstorj.io/private/process.cleanup.func1:380\n\tgithub.com/spf13/cobra.(*Command).execute:842\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:950\n\tgithub.com/spf13/cobra.(*Command).Execute:887\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.ExecCustomDebug:70\n\tmain.main:338\n\truntime.main:204”}
Error: trust: failed to fetch from source “https://tardigrade.io/trusted-satellites”: HTTP source: Get “https://tardigrade.io/trusted-satellites”: x509: certificate signed by unknown authority
any ideas what could be wrong?
Thank you
Please, show the output of the
