zkSync wallet stuck on "Checking wallet"
Hi,
opening my Trezor wallet on https://wallet.zksync.io/ just shows “Checking wallet” forever:
Their testnet is working fine with Trezor (https://rinkeby.zksync.io/).
Can somebody with a Trezor confirm? Thanks!
I can confirm. I had the same issue. You can still get your Trezor connected via MetaMask. That worked for me. Only downside is that MetaMask doesn’t allow you to use a custom derivation path. So with MetaMask you are locked to a single address while the native Trezor connector seem to allow to access the same single address plus as many additional addresses as you want.
