About Trash data
My new Debian 10 64 bits storj node version 1.12.3 has 876.9MB trash data. The node is always online.
Why is increasing trash data the last two days if the node is online? It’s normal?
Yes its normal. Node gets a delete request which it has to execute in set amount of time. After timeout this data is collected by Garbage Collection hence increase in trash data. This trash data will be deleted after 7 days.
Thank you so much by the explanation! :wink:
Is the trash included in the space occupation and therefore paid?
Trash is not paid for. As noted above it is kept for 7 days, just in case it needs to be restored.
In the same way you can’t fill the storage node data location, as free space is required for the node to run correctly, space without active customer data is not paid.
