Please scroll down to this part:
Q: What updates can be provided regarding the shutdown of us2 and europe-north-1?
A: At this point we are still finalizing the exact shutdown process and timing, and will communicate more about that as it is determined. But we do anticipate beginning to delete data from the satellites very soon.
Very soon is now
JDA
June 30, 2023, 1:43pm
42
Any idea if they are doing it by batch or are everything already be deleted?
It is being done in batches.
sitting with around 8TB more free/pending! looking forward to use for more real customer data
Vadim
July 12, 2023, 5:07pm
46
I have 180 TB of free space now.
I wonder why US2 hasn’t been shutdown first considering it only has 23TB. Currently EU-North-1 has 306TB left to delete.
flo82
July 12, 2023, 6:37pm
48
they wan’t to save money.
europe had 3.28 PB = ~5k $ per month
deletion of much data is better for them.
lyoth
July 12, 2023, 9:00pm
49
Will this bug be finally fixed?
opened 08:00PM - 06 Jun 22 UTC
Bug
Please make sure that we do not have any duplicates already open.
You ca… n ensure this by searching the issue list for this repository.
If there is a duplicate, please close your issue and add a comment to the
existing issue instead.
For more information about reporting issues, see
https://github.com/storj/storj/blob/main/docs/storagenode/CONTRIBUTING.md
GENERAL SUPPORT INFORMATION
The GitHub issue tracker is for bug reports and feature requests.
General support can be found at the following locations:
- Storj Community Forum - https://forum.storj.io
- File a ticket at https://support.storj.io/
BUG REPORT INFORMATION
Decomissioned satellites are not removed from the log after they are deleted.
I am constantly getting this logged for satellite.stefan-benten.de, even after the server was deleted.
Provide a more detailed introduction to the issue itself, and why you consider it to be a bug
**Screenshots**
**Steps to reproduce the issue:**
1. have a storage node with satellite.stefan-benten.de prior to its deletion
2. check log for the warning that "service unable to get Satellite URL"
**Describe the results you expected:**
Once a satellite is deleted, information of it should be deleted, with the exception of payment information.
**Describe the results you received:**
There is constant warning about the satellite in the logs.
**Possible Fix**
**Additional information you deem important (e.g. issue happens only occasionally):**
**Logs:**
WARN console:service unable to get Satellite URL {"Process": "storagenode", "Satellite ID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW", "error": "console: trust: satellite \"118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW\" is untrusted", "errorVerbose": "console: trust: satellite \"118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW\" is untrusted\n\tstorj.io/storj/storagenode/trust.(*Pool).getInfo:238\n\tstorj.io/storj/storagenode/trust.(*Pool).GetNodeURL:177\n\tstorj.io/storj/storagenode/console.(*Service).GetDashboardData:186\n\tstorj.io/storj/storagenode/console/consoleapi.(*StorageNode).StorageNode:45\n\tnet/http.HandlerFunc.ServeHTTP:2047\n\tgithub.com/gorilla/mux.(*Router).ServeHTTP:210\n\tnet/http.serverHandler.ServeHTTP:2879\n\tnet/http.(*conn).serve:1930"}
**Your environment**
- Operating system and version: Ubuntu 20.04
- Additional environment details (Raspberry PI, Docker, VMWare, etc.): docker
Because I am still getting the message on my oldest node from Stefan satellite, and I’m pretty sure I will get more message after the 2 test satellites are decommissioned.
Vadim
July 21, 2023, 4:28am
51
Interesting my nodes show that i have 7.6 TB from this satellite.
Maybe it will be deleted soon by GC…?!
Alexey
July 22, 2023, 2:44am
54
My nodes still has 241.31 GB data for EUN1, and 14.13 GB for US2.
By the way, the one node is missing the blob folder for EUN1 completely.
Should we completely remove the folders of US2 and EUN1 now that therte is no more data on them but some nodes still have the blob folders?
EUN1 is not even reachable, so it wont send the deletion command anymore I have just checked and I have a few GB left of blobs on each of my nodes (~15GB on each).
In the case of US2 I have around 800 MiB on each node.
Regarding trash in both satellites there are only a few megabytes now.
Is there any plan to completely remove these?
Vadim
July 25, 2023, 9:28am
56
Also I wold asc will it Be returned held amount this month?
I also have 7tb of data from this satellite when it will be deleted?
How can I tell which folder is from which satellite?
bre
July 25, 2023, 2:38pm
58
The team is currently working on some solutions and will post here when they are officially ready.
How do you check how much data is available for one satellite?
