my node is now running since 24h_ what is a storj audit? do i make the audit for myself?
will it happen where will it be logged?
meanwhile i tested some scripts found in the forum:
thanks for the fast answer.
i have 0% success rate_
is there something I have done wrong while setting up my node?
or how long does it takes to sync the node correctly?
actually there was a recoverable failed audit.
just any tip where to start or search.
and i have repair upload and download rate at 0%__ thanks for any links or advices
The audit that your storage node received had a recoverable error, so don’t worry about it.
Repair traffic only happens when a satellite repairs some data and your storage node can be involved in it. More data and free space, the more chances that your node is needed for any repair operations.
You don’t have to worry about repairs either.
Please, bear in mind that your storage node is new hence it’s in the vetting process so the amount of data that it will receive before it is vetted is lower. Your node should be vetted once it passes 100 audits.
You should also keep in mind that unless you are redirecting your logs to a file outside of the docker container (an advanced setup), each time you remove and recreate the storagenode container the logs will be erased. Since all of the stats produced by that script are from the docker logs, if you run it right after the container is created (for example, right after the node software is updated), your stats from that script will all be reset to zero since there is no historical log to source from.
Eventually there will be a more robust dashboard that should show many of these stats, but for now the logs and scripts are all we have.
No problem Milaas! That’s what everyone is here for!
Once you are more comfortable with the storj software, the method for redirecting the logs to an external file is outlined here. It is a bit advanced and if done incorrectly could leave you with no logs at all. So for now I would focus on reliability and uptime of your node.
I have a few questions about the article https://documentation.storj.io/resources/faq/redirect-logs, which config.yaml file do I edit? Do I have to create it? Where is it located or where do I put it? Do I have to pass it to Docker in the command?
The problem is that the node running inside the container, it doesn’t have such directory as /home/pi, because you haven’t mapped it in the docker run command with a --mount option. So, you should redirect to the one of mapped locations.
For example, /app/config/storagenode.log. This file storagenode.log will be available from the host in the storage location.
