Audit scores dropping on ap1; Storj is working on a fix, SNO's don't need to do anything. ERROR piecedeleter could not send delete piece to trash >> Pieces error: v0pieceinfodb: sql: no rows in result set
Edit: Upon further investigation we’ve noticed this issue is causing deleted pieces to still be audited and scores are dropping on ap1 as a result. We’ve seen scores as low as 80% already (as of 2021-07-23T10:00:00Z). Nodes may be at risk if this persists.
Two of my nodes suddenly started getting hit by massive amounts of errors like this at the same time. I don’t think I’ve seen these before and it doesn’t look like they’ve been mentioned on the forum before. Deletes from other satellites seem to still work fine, but it looks like something got seriously messed up for this satellite. The strange thing is that it started happening on two separate nodes at the same time.
2021-07-22T16:03:45.596Z ERROR piecedeleter could not send delete piece to trash {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Piece ID": "XV6EQC6XJ4DDGEK4SJPQYFZZE24HLWLFKYEUUQH7ZAPT7CZLJLGQ", "error": "pieces error: v0pieceinfodb: sql: no rows in result set", "errorVerbose": "pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
Is anyone else seeing this? Any idea what might be causing this?
Edit: I checked the integrity of databases, they are all fine.
Edit2: Despite the error, the pieces are actually being moved to trash. So the deletes are still working. Just generating tons of errors.
I can confirm I am seeing a huge wall of error all pertaining to 121RT
Same here.͏͏͏͏͏͏͏͏͏͏͏
same here and my audit status is dropping … :worried:
Me too! Tons of them on every node…
same here. many errors
Can’t confirm. All my nodes despite these errors are at 100% audit score.
I have same ERRORS on different nodes.
It coldt be nodes problems on so massive way
@Alexey this errors need erjently attention on developers
@littleskunk
Edit: It did cause audit issues later on. More info in the rest of this thread.
At this point I see no reason for alarm. This issue will not cause audit failures. They are unrelated. Pieces are being moved to trash as they should. Most likely the messy logs are the worst part of this issue.
While I do have a drop in audit score on us2, this is related to a different issue mentioned here: Audit weirdness (us2 satellite). (Team aware. No additional information is needed) That may be what @LinuxNet is seeing too.
I’m seeing the same thing as well. I also got an audit warning. I haven’t seen one of those in so long!
I think it is related, as i also have audit drop on
ap1.storj.io:7777
Audit drop cannot be related to this issue. It could be failed audit due to timeout if you don’t see any GET_AUDIT failures in your log.
Also the same issue on my node. I have realized from the WebUI dashboard that Audit massivley dropped and after that I had a look into the log.
The log is showing the same errors as described by the initiator affected by the same satelite.
2021-07-23T09:06:32.189+0200 ERROR piecedeleter could not send delete piece to trash {“Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Piece ID”: “GTHEHYJMEARL73MH4BLYELZDVL3PNNWRIQRIW2YQED4KHXPFJGIQ”, “error”: "pieces error: v0pieceinfodb: sql: no rows in result set", “errorVerbose”: "pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.
Also all the database do not show an error and all of thems seems to be okay:
**find ./ -maxdepth 1 -iname "*.db" -print0 -exec sqlite3 '{}' 'PRAGMA integrity_check;' ';'**
./used_serial.dbok
./satellites.dbok
./pieceinfo.dbok
./notifications.dbok
./piece_expiration.dbok
./bandwidth.dbok
./piece_spaced_used.dbok
./orders.dbok
./heldamount.dbok
./storage_usage.dbok
./secret.dbok
./reputation.dbok
./pricing.dbok
./info.dbok
Environment:
  • Operating System: Raspbian GNU/Linux 10 (buster)
  • Kernel: Linux 5.10.17-v7l+
  • Architecture: arm
Docker image:
  • docker pull storjlabs/storagenode:latest (v1.34.3)
At the moment I’m just observing the log for AUDIT entries and check it the mentioned satelite is generating audit errors.
What else can we do to get rid of this error log entries?
Is there any analyzing progress from storj ongoing?
yeah i’m also seeing a failed audit on ap1 today…
all the deletes sort of overloaded my current logging solution, so lost ability to track it well…
the audit failures are a network thing… not storage, and most nodes seems to be affected or should expect to see it… or thats what my nodes seems to indicate anyways…
Yes, you’re right. I’m going to have to eat my words here. Here’s a log for a piece I failed an audit for on that satellite as well.
2021-07-22T16:01:47.118Z        INFO    piecedeleter    delete piece sent to trash      {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Piece ID": "TCXVAGYEEF5ZLT3WLCQUOJDWWRJAE7OBLG6T4BKLTV5MYLLHGWKQ"}
2021-07-22T16:37:57.772Z        ERROR   piecedeleter    could not send delete piece to trash    {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Piece ID": "TCXVAGYEEF5ZLT3WLCQUOJDWWRJAE7OBLG6T4BKLTV5MYLLHGWKQ", "error": "pieces error: v0pieceinfodb: sql: no rows in result set", "errorVerbose": "pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-07-22T17:39:52.936Z        ERROR   piecedeleter    could not send delete piece to trash    {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Piece ID": "TCXVAGYEEF5ZLT3WLCQUOJDWWRJAE7OBLG6T4BKLTV5MYLLHGWKQ", "error": "pieces error: v0pieceinfodb: sql: no rows in result set", "errorVerbose": "pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-07-22T18:42:59.312Z        ERROR   piecedeleter    could not send delete piece to trash    {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Piece ID": "TCXVAGYEEF5ZLT3WLCQUOJDWWRJAE7OBLG6T4BKLTV5MYLLHGWKQ", "error": "pieces error: v0pieceinfodb: sql: no rows in result set", "errorVerbose": "pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-07-22T19:36:23.421Z        ERROR   piecedeleter    could not send delete piece to trash    {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Piece ID": "TCXVAGYEEF5ZLT3WLCQUOJDWWRJAE7OBLG6T4BKLTV5MYLLHGWKQ", "error": "pieces error: v0pieceinfodb: sql: no rows in result set", "errorVerbose": "pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-07-22T20:44:26.006Z        ERROR   piecedeleter    could not send delete piece to trash    {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Piece ID": "TCXVAGYEEF5ZLT3WLCQUOJDWWRJAE7OBLG6T4BKLTV5MYLLHGWKQ", "error": "pieces error: v0pieceinfodb: sql: no rows in result set", "errorVerbose": "pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-07-22T21:50:08.390Z        ERROR   piecedeleter    could not send delete piece to trash    {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Piece ID": "TCXVAGYEEF5ZLT3WLCQUOJDWWRJAE7OBLG6T4BKLTV5MYLLHGWKQ", "error": "pieces error: v0pieceinfodb: sql: no rows in result set", "errorVerbose": "pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-07-22T23:03:24.704Z        ERROR   piecedeleter    could not send delete piece to trash    {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Piece ID": "TCXVAGYEEF5ZLT3WLCQUOJDWWRJAE7OBLG6T4BKLTV5MYLLHGWKQ", "error": "pieces error: v0pieceinfodb: sql: no rows in result set", "errorVerbose": "pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-07-23T00:07:04.707Z        ERROR   piecedeleter    could not send delete piece to trash    {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Piece ID": "TCXVAGYEEF5ZLT3WLCQUOJDWWRJAE7OBLG6T4BKLTV5MYLLHGWKQ", "error": "pieces error: v0pieceinfodb: sql: no rows in result set", "errorVerbose": "pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-07-23T00:57:23.360Z        ERROR   piecedeleter    could not send delete piece to trash    {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Piece ID": "TCXVAGYEEF5ZLT3WLCQUOJDWWRJAE7OBLG6T4BKLTV5MYLLHGWKQ", "error": "pieces error: v0pieceinfodb: sql: no rows in result set", "errorVerbose": "pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-07-23T01:42:23.002Z        INFO    piecestore      download started        {"Piece ID": "TCXVAGYEEF5ZLT3WLCQUOJDWWRJAE7OBLG6T4BKLTV5MYLLHGWKQ", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "GET_AUDIT"}
2021-07-23T01:42:23.009Z        ERROR   piecestore      download failed {"Piece ID": "TCXVAGYEEF5ZLT3WLCQUOJDWWRJAE7OBLG6T4BKLTV5MYLLHGWKQ", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "GET_AUDIT", "error": "file does not exist", "errorVerbose": "file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:73\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:534\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:217\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:58\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:102\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:60\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:95\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51"}
2021-07-23T01:55:10.603Z        ERROR   piecedeleter    could not send delete piece to trash    {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Piece ID": "TCXVAGYEEF5ZLT3WLCQUOJDWWRJAE7OBLG6T4BKLTV5MYLLHGWKQ", "error": "pieces error: v0pieceinfodb: sql: no rows in result set", "errorVerbose": "pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-07-23T03:10:47.095Z        ERROR   piecedeleter    could not send delete piece to trash    {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Piece ID": "TCXVAGYEEF5ZLT3WLCQUOJDWWRJAE7OBLG6T4BKLTV5MYLLHGWKQ", "error": "pieces error: v0pieceinfodb: sql: no rows in result set", "errorVerbose": "pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-07-23T04:10:43.608Z        ERROR   piecedeleter    could not send delete piece to trash    {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Piece ID": "TCXVAGYEEF5ZLT3WLCQUOJDWWRJAE7OBLG6T4BKLTV5MYLLHGWKQ", "error": "pieces error: v0pieceinfodb: sql: no rows in result set", "errorVerbose": "pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-07-23T05:03:23.132Z        ERROR   piecedeleter    could not send delete piece to trash    {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Piece ID": "TCXVAGYEEF5ZLT3WLCQUOJDWWRJAE7OBLG6T4BKLTV5MYLLHGWKQ", "error": "pieces error: v0pieceinfodb: sql: no rows in result set", "errorVerbose": "pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-07-23T06:06:54.715Z        ERROR   piecedeleter    could not send delete piece to trash    {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Piece ID": "TCXVAGYEEF5ZLT3WLCQUOJDWWRJAE7OBLG6T4BKLTV5MYLLHGWKQ", "error": "pieces error: v0pieceinfodb: sql: no rows in result set", "errorVerbose": "pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-07-23T07:26:42.182Z        ERROR   piecedeleter    could not send delete piece to trash    {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Piece ID": "TCXVAGYEEF5ZLT3WLCQUOJDWWRJAE7OBLG6T4BKLTV5MYLLHGWKQ", "error": "pieces error: v0pieceinfodb: sql: no rows in result set", "errorVerbose": "pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
Two things of note here. It did actually successfully delete the piece the first time and keeps repeating the delete. And it’s also still auditing these pieces. This issue is separate from the issue we saw on us2.
I think there is now reason for some concern.
It looks to me like the satellite isn’t properly finishing the delete on its end, so piece metadata is still there. It could be an issue with the delete cache used to process deletes asynchronously. Either way, the satellite thinks a piece that was already deleted still exists… Houston, we have a problem!
All my 5 nodes, the same trouble.
It also affects the audit.
and heading into a Friday in the US.
Yip, two of my nodes have the same issue. So it looks like ap1.storj.io sent a piece to trash yesterday, has since been trying to repeat the delete (and failing) and is now trying to audit me on it.
I’m now at 7.48% and counting audit failures on ap1.storj.io
2021-07-22T21:04:53.061+0100    INFO    piecedeleter    delete piece sent to trash      {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Piece ID": "HXWYINXV6SK2UB2NE5QIS55UQUXAWVZ72M6IJ3DBWPIBIPVDSKPA"}
2021-07-22T22:11:15.990+0100    ERROR   piecedeleter    could not send delete piece to trash    {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Piece ID": "HXWYINXV6SK2UB2NE5QIS55UQUXAWVZ72M6IJ3DBWPIBIPVDSKPA", "error": "pieces error: v0pieceinfodb: sql: no rows in result set", "errorVerbose": "pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-07-23T00:37:27.293+0100	ERROR	piecedeleter	could not send delete piece to trash	{"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Piece ID": "HXWYINXV6SK2UB2NE5QIS55UQUXAWVZ72M6IJ3DBWPIBIPVDSKPA", "error": "pieces error: v0pieceinfodb: sql: no rows in result set", "errorVerbose": "pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-07-23T01:26:58.692+0100	ERROR	piecedeleter	could not send delete piece to trash	{"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Piece ID": "HXWYINXV6SK2UB2NE5QIS55UQUXAWVZ72M6IJ3DBWPIBIPVDSKPA", "error": "pieces error: v0pieceinfodb: sql: no rows in result set", "errorVerbose": "pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-07-23T02:19:01.578+0100	ERROR	piecedeleter	could not send delete piece to trash	{"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Piece ID": "HXWYINXV6SK2UB2NE5QIS55UQUXAWVZ72M6IJ3DBWPIBIPVDSKPA", "error": "pieces error: v0pieceinfodb: sql: no rows in result set", "errorVerbose": "pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-07-23T03:35:41.008+0100	ERROR	piecedeleter	could not send delete piece to trash	{"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Piece ID": "HXWYINXV6SK2UB2NE5QIS55UQUXAWVZ72M6IJ3DBWPIBIPVDSKPA", "error": "pieces error: v0pieceinfodb: sql: no rows in result set", "errorVerbose": "pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-07-23T04:36:21.603+0100	ERROR	piecedeleter	could not send delete piece to trash	{"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Piece ID": "HXWYINXV6SK2UB2NE5QIS55UQUXAWVZ72M6IJ3DBWPIBIPVDSKPA", "error": "pieces error: v0pieceinfodb: sql: no rows in result set", "errorVerbose": "pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-07-23T05:31:02.268+0100	ERROR	piecedeleter	could not send delete piece to trash	{"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Piece ID": "HXWYINXV6SK2UB2NE5QIS55UQUXAWVZ72M6IJ3DBWPIBIPVDSKPA", "error": "pieces error: v0pieceinfodb: sql: no rows in result set", "errorVerbose": "pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-07-23T06:22:48.186+0100	ERROR	piecedeleter	could not send delete piece to trash	{"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Piece ID": "HXWYINXV6SK2UB2NE5QIS55UQUXAWVZ72M6IJ3DBWPIBIPVDSKPA", "error": "pieces error: v0pieceinfodb: sql: no rows in result set", "errorVerbose": "pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-07-23T07:42:33.827+0100	ERROR	piecedeleter	could not send delete piece to trash	{"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Piece ID": "HXWYINXV6SK2UB2NE5QIS55UQUXAWVZ72M6IJ3DBWPIBIPVDSKPA", "error": "pieces error: v0pieceinfodb: sql: no rows in result set", "errorVerbose": "pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-07-23T08:54:48.269+0100	ERROR	piecedeleter	could not send delete piece to trash	{"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Piece ID": "HXWYINXV6SK2UB2NE5QIS55UQUXAWVZ72M6IJ3DBWPIBIPVDSKPA", "error": "pieces error: v0pieceinfodb: sql: no rows in result set", "errorVerbose": "pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-07-23T09:56:22.474+0100	INFO	piecestore	download started	{"Piece ID": "HXWYINXV6SK2UB2NE5QIS55UQUXAWVZ72M6IJ3DBWPIBIPVDSKPA", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "GET_AUDIT"}
2021-07-23T09:56:24.372+0100	ERROR	piecestore	download failed	{"Piece ID": "HXWYINXV6SK2UB2NE5QIS55UQUXAWVZ72M6IJ3DBWPIBIPVDSKPA", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "GET_AUDIT", "error": "file does not exist", "errorVerbose": "file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:73\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:534\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:217\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:58\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:102\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:60\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:95\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51"}
Looks like test data downloaded in April:
2021-04-14T16:07:51.104+0100|INFO|piecestore|upload started|{Piece ID: HXWYINXV6SK2UB2NE5QIS55UQUXAWVZ72M6IJ3DBWPIBIPVDSKPA, Satellite ID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, Action: PUT, Available Space: 10206704622}|
2021-04-14T16:07:51.106+0100|INFO|piecestore|uploaded|{Piece ID: HXWYINXV6SK2UB2NE5QIS55UQUXAWVZ72M6IJ3DBWPIBIPVDSKPA, Satellite ID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, Action: PUT, Size: 512}|
I’m dropping audits too.
|2021-07-23T10:53:52.758+0200|ERROR|piecedeleter|could not send delete piece to trash|{Satellite ID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, Piece ID: HPT7V6TWU7O62PYGIPPDOAOUK6TYGYPLACTJT7GLPDH75P4EFQPQ, error: pieces error: v0pieceinfodb: sql: no rows in result set, errorVerbose: pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57}|
|2021-07-23T10:53:52.772+0200|ERROR|piecedeleter|could not send delete piece to trash|{Satellite ID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, Piece ID: FHMYFMLV3355OXD2LPZSQZT2QQSST4WR2LIMYGIF3QRCWGHB3Z7Q, error: pieces error: v0pieceinfodb: sql: no rows in result set, errorVerbose: pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57}|
|2021-07-23T10:53:52.772+0200|ERROR|piecedeleter|could not send delete piece to trash|{Satellite ID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, Piece ID: E5MKWEVL22QWNLUDB6LC37XVJRRBY6TEPXMS7A764F5D6IIQV4HA, error: pieces error: v0pieceinfodb: sql: no rows in result set, errorVerbose: pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57}|
|2021-07-23T10:53:52.773+0200|ERROR|piecedeleter|could not send delete piece to trash|{Satellite ID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, Piece ID: D6YUCIL5S6MCWE44X5GL32VGSFOY5MGOWZEFJVAYZJDPNMGEN2LQ, error: pieces error: v0pieceinfodb: sql: no rows in result set, errorVerbose: pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57}|
|2021-07-23T10:53:52.773+0200|ERROR|piecedeleter|could not send delete piece to trash|{Satellite ID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, Piece ID: J345W2RRWV2NMBPKZ63NUS57MAXVZWHBHLJZFQ7KZX6UE64QGN4Q, error: pieces error: v0pieceinfodb: sql: no rows in result set, errorVerbose: pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57}|
|2021-07-23T10:53:52.774+0200|ERROR|piecedeleter|could not send delete piece to trash|{Satellite ID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, Piece ID: ICQJ36FUU25OROIQKJ6NIZIDPU5HVDX4WLMBPRD4B7NEKNV6P3JA, error: pieces error: v0pieceinfodb: sql: no rows in result set, errorVerbose: pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57}|
|2021-07-23T10:53:52.775+0200|ERROR|piecedeleter|could not send delete piece to trash|{Satellite ID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, Piece ID: 6YP23RFNKZBPJI36DXT43QJTSGWMQFWUBIXHBJXCM7YKDXE4EMMA, error: pieces error: v0pieceinfodb: sql: no rows in result set, errorVerbose: pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57}|
|2021-07-23T10:53:52.777+0200|ERROR|piecedeleter|could not send delete piece to trash|{Satellite ID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, Piece ID: OMCHVQ4ZVQOJJY6RNMVQRQBB7XDBKTYEUHSOELQVC3JZUTNHL37Q, error: pieces error: v0pieceinfodb: sql: no rows in result set, errorVerbose: pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57}|
|2021-07-23T10:53:52.778+0200|ERROR|piecedeleter|could not send delete piece to trash|{Satellite ID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, Piece ID: JWFOCKPLQ3AL337Y2RN7776PCTZOYKQ4VHDZBWXGQPN7E5KA7ZKA, error: pieces error: v0pieceinfodb: sql: no rows in result set, errorVerbose: pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57}|
|2021-07-23T10:53:52.780+0200|ERROR|piecedeleter|could not send delete piece to trash|{Satellite ID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, Piece ID: CJPSMTLQKHXINOQFTYJ2GBJ3GJL2HIIVV6HBRDE2JCOEDKR3TX4A, error: pieces error: v0pieceinfodb: sql: no rows in result set, errorVerbose: pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57}|
|2021-07-23T10:53:52.780+0200|ERROR|piecedeleter|could not send delete piece to trash|{Satellite ID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, Piece ID: 3H7IYAIGKTVQSN7HNIMBRYB43B5OAXMWTDSF5IYM6RPWA7UIM2KQ, error: pieces error: v0pieceinfodb: sql: no rows in result set, errorVerbose: pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57}|
|2021-07-23T10:53:52.781+0200|ERROR|piecedeleter|could not send delete piece to trash|{Satellite ID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, Piece ID: VKUWN3BVCXWOREBT65XFXQCPP7ROCBSUIVFDMKVCKLARYLO2VABQ, error: pieces error: v0pieceinfodb: sql: no rows in result set, errorVerbose: pieces error: v0pieceinfodb: sql: no rows in result set\n\tstorj.io/storj/storagenode/storagenodedb.(*v0PieceInfoDB).Get:131\n\tstorj.io/storj/storagenode/pieces.(*Store).MigrateV0ToV1:404\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:348\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57}|
I’ll probably shut mine down at 80%. Currently 91%.
