I have two storj nodes
Both nodes are marked with “STATUS Offline” and “QUIC Misconfigured”
What could be the problem?
These errors appear in the log:
| 2025-03-06T22:47:30+01:00 | ERROR | contact:service | ping satellite failed | {Satellite ID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, attempts: 1, error: ping satellite: context canceled, errorVerbose: ping satellite: context canceled\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:210\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:158\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:89\n\tstorj.io/common/sync2.(*Cycle).Run:102\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78} |
| 2025-03-06T22:48:46+01:00 | ERROR | contact:service | ping satellite failed | {Satellite ID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, attempts: 2, error: ping satellite: context canceled, errorVerbose: ping satellite: context canceled\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:210\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:158\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:89\n\tstorj.io/common/sync2.(*Cycle).Run:102\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78} |
| 2025-03-06T22:48:58+01:00 | WARN | console:service | unable to get Satellite URL | {Satellite ID: 118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW, error: console: trust: satellite is untrusted, errorVerbose: console: trust: satellite is untrusted\n\tstorj.io/storj/storagenode/trust.init:29\n\truntime.doInit:6527\n\truntime.doInit:6504\n\truntime.doInit:6504\n\truntime.doInit:6504\n\truntime.doInit:6504\n\truntime.doInit:6504\n\truntime.main:233} |
| 2025-03-06T22:49:20+01:00 | ERROR | contact:service | ping satellite failed | {Satellite ID: 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs, attempts: 1, error: ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 83.45.53.42:28967: connect: connection timed out, errorVerbose: ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 83.45.53.42:28967: connect: connection timed out\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:216\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:158\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:89\n\tstorj.io/common/sync2.(*Cycle).Run:102\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78} |
| 2025-03-06T22:49:21+01:00 | ERROR | contact:service | ping satellite failed | {Satellite ID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S, attempts: 1, error: ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 83.45.53.42:28967: connect: connection timed out, errorVerbose: ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 83.45.53.42:28967: connect: connection timed out\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:216\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:158\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:89\n\tstorj.io/common/sync2.(*Cycle).Run:102\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78} |
| 2025-03-06T22:49:22+01:00 | ERROR | contact:service | ping satellite failed | {Satellite ID: 1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE, attempts: 1, error: ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 83.45.53.42:28967: connect: connection timed out, errorVerbose: ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 83.45.53.42:28967: connect: connection timed out\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:216\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:158\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:89\n\tstorj.io/common/sync2.(*Cycle).Run:102\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78} |
| 2025-03-06T22:49:38+01:00 | ERROR | contact:service | ping satellite failed | {Satellite ID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, attempts: 3, error: ping satellite: context canceled, errorVerbose: ping satellite: context canceled\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:210\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:158\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:89\n\tstorj.io/common/sync2.(*Cycle).Run:102\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78} |
| 2025-03-06T22:50:03+01:00 | ERROR | contact:service | ping satellite failed | {Satellite ID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, attempts: 4, error: ping satellite: rpc: tcp connector failed: rpc: dial tcp 34.126.92.94:7777: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond., errorVerbose: ping satellite: rpc: tcp connector failed: rpc: dial tcp 34.126.92.94:7777: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190} |
| 2025-03-06T22:50:09+01:00 | INFO | reputation:service | node scores updated | {Satellite ID: 1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE, Total Audits: 1417540, Successful Audits: 1389454, Audit Score: 1, Online Score: 0.9189551932522501, Suspension Score: 1, Audit Score Delta: 0, Online Score Delta: 0, Suspension Score Delta: 0} |
| 2025-03-06T22:50:31+01:00 | INFO | reputation:service | node scores updated | {Satellite ID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S, Total Audits: 1656184, Successful Audits: 1628668, Audit Score: 1, Online Score: 0.9108568253408293, Suspension Score: 1, Audit Score Delta: 0, Online Score Delta: 0, Suspension Score Delta: 0} |
| 2025-03-06T22:50:31+01:00 | INFO | reputation:service | node scores updated | {Satellite ID: 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs, Total Audits: 2479322, Successful Audits: 2438067, Audit Score: 1, Online Score: 0.9112293976252962, Suspension Score: 1, Audit Score Delta: 0, Online Score Delta: 0, Suspension Score Delta: 0} |
| 2025-03-06T22:50:31+01:00 | ERROR | reputation:chore | reputation chore failed | {error: reputation: rpc: tcp connector failed: rpc: dial tcp 34.126.92.94:7777: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond., errorVerbose: reputation: rpc: tcp connector failed: rpc: dial tcp 34.126.92.94:7777: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190} |
| 2025-03-06T22:50:32+01:00 | ERROR | contact:service | ping satellite failed | {Satellite ID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, attempts: 5, error: ping satellite: rpc: tcp connector failed: rpc: dial tcp 34.126.92.94:7777: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond., errorVerbose: ping satellite: rpc: tcp connector failed: rpc: dial tcp 34.126.92.94:7777: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190} |
| 2025-03-06T22:51:31+01:00 | ERROR | contact:service | ping satellite failed | {Satellite ID: 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs, attempts: 2, error: ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 79.157.87.123:28967: connect: connection timed out, errorVerbose: ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 79.157.87.123:28967: connect: connection timed out\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:216\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:158\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:89\n\tstorj.io/common/sync2.(*Cycle).Run:102\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78} |
| 2025-03-06T22:51:32+01:00 | ERROR | contact:service | ping satellite failed | {Satellite ID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S, attempts: 2, error: ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 83.45.53.42:28967: connect: connection timed out, errorVerbose: ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 83.45.53.42:28967: connect: connection timed out\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:216\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:158\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:89\n\tstorj.io/common/sync2.(*Cycle).Run:102\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78} |
