Certificate on forum is expired
Would you mind renewing your certificate?
* * Certification info:
*   Subject:
*     OU=Domain Control Validated
*     OU=PositiveSSL Wildcard
*     CN=*.geekshed.net
*   Issuer:
*     C=GB
  • ST=Greater Manchester
  • L=Salford
  • O=COMODO CA Limited
  • CN=COMODO RSA Domain Validation Secure Server CA
  • Public key algorithm: rsaEncryption (2048 bits)
  • Sign algorithm sha256WithRSAEncryption
  • Valid since Jan 6 00:00:00 2017 GM to Jan 6 23:59:59 2020 GM
    • Cipher info:
  • Version: TLSv1/SSLv3, cipher AES256-GCM-SHA384 (256 bits)
  • Connection failed (certificate has expired.? (10))
@selea sorry I meant to reply back sooner. I do see the certificate properly with a hard refresh. wd you mind clearing your cache and seeing if the behavior is still present? thank you!
Hi,
It seems like my post was inaccurately moved to this thread by @Alexey from IRC Server for Chat
It was meant for the IRC-server operator and not storj.
ah Ok !
Thank you @selea.
@selea Returned your comment back, sorry for confusion!
the certificate on forum has been expired too, but now ok
Did you ever get a browser error saying that the cert had expired? I didn’t see one. I was confused when I checked the cert in Chrome and it didn’t complain about the cert being expired but then showed the expired cert. Doing a hard reload fixed it; I think it’s a quirk of Chrome that it somehow hadn’t loaded the cert that it displayed.
The same here. The browser were not complaining, but if open the certificate it’s outdated.
The Ctrl+F5 is the solution
