Ongoing Storj v3 development. Decentralized cloud object storage that is affordable, easy to use, private, and secure. - storj/storj
Gracefull Exit
We are close to the finish line but it is not completed. Don’t execute it. Don’t test it. Don’t even try it. If you are waiting for gracefull exit we can use the time to talk about it first.
Remove default concurrency limit
By default a storage node had a limit of 6 concurrent transfers and will reject additional uploads until one of the ongoing transfers is finished. We believe with dRPC the limit is not needed anymore. By default the storage nodes will now take as many uploads as they can. You can still set the limit in your config file like before. Removing it from the config will reset it to the new default value.
Storj-sim requires postgres
Storj-sim is our local test network. It now requires postgres. We have updated the wiki: https://github.com/storj/storj/wiki/Test-network
naxbc
October 28, 2019, 3:23pm
2
How about the Raspberry´s nodes? Won´t they be overwhelmed now with this change?
What is the “new default value”?
why are Kademlia entries still present in the config.yaml if Kademlia is no longer used, also web dashboard is not displaying correctly and undefined.undefinned.undefined is displayed
Your Storage Node Stats
Current period: October
Online
Node Version
vundefined.undefined.undefined
Choose your satellite: All satellites
Utilization & Remaining
Bandwidth Used This Month
315.53GB
Disk Space Used This Month
1.72PB*h
Remaining on the Node
Bandwidth Remaining
99.68TB
Disk Space Remaining
1.32TB
As noted in the changelog, you can still continue setting your own concurrency limit on your Pi´s config file as before?
Because we will never touch your config file. Take a look at your logfile and you should notice some warnings about deprecated confilg values.
naxbc
October 28, 2019, 4:33pm
6
Apparently yes, I´ll keep monitoring it, thanks.
I do see this one (gracefulexit:chore running graceful exit chore.) also can I stop rm the container and then delete the config.yaml and pull, docker run so that I could get a new clean config.yaml with out doing any harm to the node
bovcan
October 28, 2019, 5:52pm
8
is new version out already? my node is still 0.23.5
Your node may take up to 72 hours to auto-update if you are using Watchtower. There is no need to worry if your node has not updated itself yet.
Vadim
October 28, 2019, 6:34pm
10
Dashboard is gone wired on chrome
on edge looks OK
Vadim
October 28, 2019, 6:36pm
11
Whay today my node made update if it was up to date?
my node was update some days ago 0.24.5
today updated once more to 0.24.5 but file size is different from previus.
Vadim
October 28, 2019, 6:39pm
12
My bad it was 23.5 now it 24.5 but dashboard on chrome is wired
Vadim
October 28, 2019, 6:43pm
14
Thanks gone mutch better.
Odmin
October 29, 2019, 5:42am
15
@littleskunk I still keep eyes on drpc errors, here some after node upgrade.
docker logs storagenode 2>&1 | grep drpc
2019-10-28T22:02:51.098Z INFO piecestore download failed {"Piece ID": "3YUPIMXWIA6H2UFMYPS3THD7RZV44UUJXPLWHEWBJQHYDMMUIWUA", "SatelliteID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW", "Action": "GET", "error": "piecestore: piecestore protocol: write tcp 172.17.0.3:28967->34.67.235.103:36344: write: connection reset by peer", "errorVerbose": "piecestore: piecestore protocol: write tcp 172.17.0.3:28967->34.67.235.103:36344: write: connection reset by peer\n\tstorj.io/drpc/drpcstream.(*Stream).pollWrite:162\n\tstorj.io/drpc/drpcwire.SplitN:25\n\tstorj.io/drpc/drpcstream.(*Stream).RawWrite:199\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:231\n\tstorj.io/storj/pkg/pb.(*drpcPiecestoreDownloadStream).Send:905\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload.func3:565\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2019-10-28T22:09:08.810Z INFO piecestore download failed {"Piece ID": "3YUPIMXWIA6H2UFMYPS3THD7RZV44UUJXPLWHEWBJQHYDMMUIWUA", "SatelliteID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW", "Action": "GET", "error": "piecestore: piecestore protocol: write tcp 172.17.0.3:28967->34.67.235.103:43636: use of closed network connection", "errorVerbose": "piecestore: piecestore protocol: write tcp 172.17.0.3:28967->34.67.235.103:43636: use of closed network connection\n\tstorj.io/drpc/drpcstream.(*Stream).pollWrite:162\n\tstorj.io/drpc/drpcwire.SplitN:25\n\tstorj.io/drpc/drpcstream.(*Stream).RawWrite:199\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:231\n\tstorj.io/storj/pkg/pb.(*drpcPiecestoreDownloadStream).Send:905\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload.func3:565\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2019-10-28T23:12:51.721Z INFO piecestore download failed {"Piece ID": "3YUPIMXWIA6H2UFMYPS3THD7RZV44UUJXPLWHEWBJQHYDMMUIWUA", "SatelliteID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW", "Action": "GET", "error": "piecestore: piecestore protocol: write tcp 172.17.0.3:28967->34.67.235.103:53050: write: broken pipe", "errorVerbose": "piecestore: piecestore protocol: write tcp 172.17.0.3:28967->34.67.235.103:53050: write: broken pipe\n\tstorj.io/drpc/drpcstream.(*Stream).pollWrite:162\n\tstorj.io/drpc/drpcwire.SplitN:25\n\tstorj.io/drpc/drpcstream.(*Stream).RawWrite:199\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:231\n\tstorj.io/storj/pkg/pb.(*drpcPiecestoreDownloadStream).Send:905\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload.func3:565\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2019-10-29T00:42:51.155Z INFO piecestore download failed {"Piece ID": "3YUPIMXWIA6H2UFMYPS3THD7RZV44UUJXPLWHEWBJQHYDMMUIWUA", "SatelliteID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW", "Action": "GET", "error": "piecestore: piecestore protocol: write tcp 172.17.0.3:28967->34.67.235.103:34192: write: broken pipe", "errorVerbose": "piecestore: piecestore protocol: write tcp 172.17.0.3:28967->34.67.235.103:34192: write: broken pipe\n\tstorj.io/drpc/drpcstream.(*Stream).pollWrite:162\n\tstorj.io/drpc/drpcwire.SplitN:25\n\tstorj.io/drpc/drpcstream.(*Stream).RawWrite:199\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:231\n\tstorj.io/storj/pkg/pb.(*drpcPiecestoreDownloadStream).Send:905\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload.func3:565\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2019-10-29T00:52:51.294Z INFO piecestore download failed {"Piece ID": "3YUPIMXWIA6H2UFMYPS3THD7RZV44UUJXPLWHEWBJQHYDMMUIWUA", "SatelliteID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW", "Action": "GET", "error": "piecestore: piecestore protocol: write tcp 172.17.0.3:28967->34.67.235.103:44670: write: broken pipe", "errorVerbose": "piecestore: piecestore protocol: write tcp 172.17.0.3:28967->34.67.235.103:44670: write: broken pipe\n\tstorj.io/drpc/drpcstream.(*Stream).pollWrite:162\n\tstorj.io/drpc/drpcwire.SplitN:25\n\tstorj.io/drpc/drpcstream.(*Stream).RawWrite:199\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:231\n\tstorj.io/storj/pkg/pb.(*drpcPiecestoreDownloadStream).Send:905\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload.func3:565\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2019-10-29T01:17:51.173Z INFO piecestore download failed {"Piece ID": "3YUPIMXWIA6H2UFMYPS3THD7RZV44UUJXPLWHEWBJQHYDMMUIWUA", "SatelliteID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW", "Action": "GET", "error": "piecestore: piecestore protocol: write tcp 172.17.0.3:28967->34.67.235.103:42654: write: broken pipe", "errorVerbose": "piecestore: piecestore protocol: write tcp 172.17.0.3:28967->34.67.235.103:42654: write: broken pipe\n\tstorj.io/drpc/drpcstream.(*Stream).pollWrite:162\n\tstorj.io/drpc/drpcwire.SplitN:25\n\tstorj.io/drpc/drpcstream.(*Stream).RawWrite:199\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:231\n\tstorj.io/storj/pkg/pb.(*drpcPiecestoreDownloadStream).Send:905\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload.func3:565\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2019-10-29T01:32:50.990Z INFO piecestore download failed {"Piece ID": "3YUPIMXWIA6H2UFMYPS3THD7RZV44UUJXPLWHEWBJQHYDMMUIWUA", "SatelliteID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW", "Action": "GET", "error": "piecestore: piecestore protocol: write tcp 172.17.0.3:28967->34.67.235.103:58346: write: broken pipe", "errorVerbose": "piecestore: piecestore protocol: write tcp 172.17.0.3:28967->34.67.235.103:58346: write: broken pipe\n\tstorj.io/drpc/drpcstream.(*Stream).pollWrite:162\n\tstorj.io/drpc/drpcwire.SplitN:25\n\tstorj.io/drpc/drpcstream.(*Stream).RawWrite:199\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:231\n\tstorj.io/storj/pkg/pb.(*drpcPiecestoreDownloadStream).Send:905\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload.func3:565\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2019-10-29T04:02:51.307Z INFO piecestore download failed {"Piece ID": "3YUPIMXWIA6H2UFMYPS3THD7RZV44UUJXPLWHEWBJQHYDMMUIWUA", "SatelliteID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW", "Action": "GET", "error": "piecestore: piecestore protocol: write tcp 172.17.0.3:28967->34.67.235.103:45890: write: broken pipe", "errorVerbose": "piecestore: piecestore protocol: write tcp 172.17.0.3:28967->34.67.235.103:45890: write: broken pipe\n\tstorj.io/drpc/drpcstream.(*Stream).pollWrite:162\n\tstorj.io/drpc/drpcwire.SplitN:25\n\tstorj.io/drpc/drpcstream.(*Stream).RawWrite:199\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:231\n\tstorj.io/storj/pkg/pb.(*drpcPiecestoreDownloadStream).Send:905\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload.func3:565\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
Details about that piece:
docker logs storagenode 2>&1 | grep "3YUPIMXWIA6H2UFMYPS3THD7RZV44UUJXPLWHEWBJQHYDMMUIWUA"
Link to Pastebin , a lot of information for this post.
jerrydp
October 29, 2019, 11:26am
16
Is this normal that I see this on my node?
I’ve never requested graceful exit
Node ID 1pXCvt4E3nczEXL1xpyyMjsNoSxf3yjfgg2AggiBo5KBJedDGK
Odmin
October 29, 2019, 11:31am
17
This information message persists on all storagenodes.
docker logs storagenode 2>&1 | grep gracefulexit
Summary
2019-10-28T19:11:53.716Z INFO gracefulexit:chore running graceful exit chore.
2019-10-28T19:26:40.084Z INFO gracefulexit:chore running graceful exit chore.
2019-10-28T19:41:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-28T19:56:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-28T20:11:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-28T20:26:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-28T20:41:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-28T20:56:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-28T21:11:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-28T21:26:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-28T21:41:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-28T21:56:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-28T22:11:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-28T22:26:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-28T22:41:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-28T22:56:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-28T23:11:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-28T23:26:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-28T23:41:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-28T23:56:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T00:11:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T00:26:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T00:41:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T00:56:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T01:11:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T01:26:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T01:41:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T01:56:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T02:11:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T02:26:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T02:41:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T02:56:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T03:11:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T03:26:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T03:41:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T03:56:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T04:11:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T04:26:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T04:41:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T04:56:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T05:11:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T05:26:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T05:41:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T05:56:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T06:11:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T06:26:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T06:41:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T06:56:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T07:11:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T07:26:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T07:41:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T07:56:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T08:11:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T08:26:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T08:41:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T08:56:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T09:11:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T09:26:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T09:41:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T09:56:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T10:11:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T10:26:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T10:41:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T10:56:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T11:11:38.409Z INFO gracefulexit:chore running graceful exit chore.
2019-10-29T11:26:38.409Z INFO gracefulexit:chore running graceful exit chore.
jerrydp
October 29, 2019, 11:34am
18
Thank you for the reply
But what does this message mean, should I worry or treat it as normal operation?
That is just an idle message from the graceful exit job. As long as you don’t call gracefull exit the job will skip all the time.
