Multinode Dashboard Payout Estimation
A small bug fix but with a huge impact. The multinode dashboard can now estimate the total payout of all storage nodes.
QA test network
You can now set up a storage node connected to our public test network. See Please join our public test network for more information.
For Customers
Uplinkng
We are working on an uplink CLI redesign. For the time being it is called uplinkng. Once development is finished we will rename uplinkng into uplink. So it will replace the current uplink binaries at some point. See [Tech Preview] Uplinkng (new enhanced uplink cli) for more information.
Try update node on windows. As ussualy, stop node, delete log, delete old exe. Copy new storagenode.exe from zip. And it is not running. Freezes on startup.
I have the same problem too - back to the late version and the update service stopped! otherwise you are out after 5 hours !! what a shit, 1 year of work almost on the ass!
Please note that your node can be offline a lot longer than 5 hours before getting disqualified. For more details about how offline score is calculated see this FAQ.
