So in your example 43.5% dropped and an absolute number of 3440 dropped?
3440 times a random order was dropped. I am not sure about the percentage. I would say with a memory limit of 50KB it is hard to give that percentage any value. We could improve the monkit data to get a better understanding of how many serial numbers have been processed. Is 3340 a high amount or a low amount compared to the total? However with 100KB my node is not dropping any serial numbers which means I would never see the additional monkit data anyway.
acting in the dark seems kinda pointless, proper tracking / logging seems like the obvious way to go, having data to predict failure or future problems would also help avoid future issuesâŚ
ofc one wouldnât want to log everything i would assume⌠more like just the amount of dedicated memory and how much is actually used⌠detailed logging could hinder performance i supposeâŚ
but atleast being able to see some basic stats from time to time on fundamental systems of the storagenodes seems quite prudent, atleast in debug mode.
It is also obvious that we have that already in place. You can start digging into it here: Guide to debug my storage node, uplink, s3 gateway, satellite
My question about the percentage was referring to the meaning of this variable in your output.
rate=0.435235
I was wondering whether that meant 43.5% was dropped or anything else? I think that caused some confusion, I may have misinterpreted it.
Iâm not worried about this âissueâ btw. I donât think itâll be a problem, Iâm just curious about what Iâm looking at.
Yes rate usually translate into percentage.
that looks really interesting, i misunderstood your earlier post, sounded a bit like there wasnât enough information, anywaysâŚ
why use 1gb if 100kb is enough tho⌠seems immensely overkill, is the memory setting for the serialâŚthingamajig always allocated memory or will it just leave the memory free if it doesnât need it?
^this
Based on my current test I could set all my 6 nodes to 100 KB per node. For the next few month they would not drop a serial number. If I set the limit to 1 GB all 6 nodes will consume exactly the same amount of memory. I have the memory in my system so I can as well assign it even if it will not be used. The advantage of the 1 GB limit comes into play when a customer is uploading or downloading more then usual. With a 100 KB limit I would start dropping serial numbers. With a 1 GB limit I wouldnât. As long as I have it available I can as well assign it.
Just got updated to 1.6.4 on my linux nodes. No problems so far.
that only leaves the question of why its on 1mb per default then⌠seems kinda on the low end of the spectrum⌠100-256mb shouldnât be unreasonable even on a rpi, even 50mb would still make so much more sense⌠i mean who cares about 50mb today⌠especially if itâs unallocated when not neededâŚ
ofc there would also be the question of what happens if the memory is set to 1gb but if it runs out at a much lower amount because the system doesnât have memory to spareâŚ
in my case my system shouldnât be able to run out of memory, even tho i have seen it peak at 95% but most of that is the arc and a few vmâs⌠which the system should release memory from if it needs memory for other stuff⌠might have something to do with that iâm running 512k recordsizesâŚ
how do i set the storagenode to 1gb for serial db memory?
got 48gb and only plan on running a couple storagenodes max⌠so might as well set it so it has ample to work with.
Check the first post.
But youâre really overthinking this⌠Check the monkit stats or let Storjlabs collect the telemetry on this and just leave it be.
As for why you wouldnât assign more, if youâre not conservative about assigning RAM use when programming, youâre going to get bloated software. This is just one very specific feature. There are many more. Start with something reasonable, see if itâs a problem. If it is you can always raise it, but it really looks like it wonât be anyway.
seems more relevant to my node than the avg node, since i donât plan on expanding fleet wise but capacity⌠also if it only takes the memory it needs, which little skunk said⌠then i see no reason not to just let it take whatever the storagenode would wantâŚ
but yeah you are most likely right⌠as usual xD i was also kinda thinking the same thing⌠but then again⌠if i might go into the extreme end of the node size spectrum, it might be wise to tweak some of the relevant settings⌠ofc doing that comes at the risk of running into issues that arenât the same as other nodes, because my settings would be unique⌠which also is something to account for⌠might make troubleshooting hell in the futureâŚ
has the docker image been released yet
Yes. Released and installed already.
Auto-updated to 1.6.4⌠no issues.
