First time poster. Just got my invitation on Friday and have setup my first 10TB node with dual ISP (1000/1000 and 500/100) on my SAS SAN.
I’m trying to understand how the uptime disqualification works, if at all as it seems it’s been discussed over time?
I’m normally do maintenance from time to time. I’m planning UPS work for example and that will lead to downtime for a few hours. Is this relevant during the beta?
Also I’m trying to figure out if having multiple A records for the FQDN of my node has any impact what so ever on redundancy for a dual ISP setup? Not currently running BGP so all routing is statically done…
I asked this question many times and did not receive a clear answer.
Most likely, if one provider breaks, half of the connections to you will not be successful. This is standard behavior for network appplications that have no fault tolerance.
Anyway if you have free disk space It’s much more profitable to run the second node on the second channel
Thanks for your response.
Yes as round-robin might be applicable some of my traffic will go down. I doubt it will be 50% as this is strongly controlled by the inconsistency of how round robin works, or not works…
Also, depending on how the method works for re-establishing a connection it might be that 100% of the connections attempts would go to the IP adress, if no additional DNS lookup will take place, in fact even if a lockup is being made, and the returned A record belongs to the failed ISP my storage node will still be seen as offline.
Currently my FQDN is a dynDNS record and it will automatically change in the event of my primary ISP going down as my default route will change, but its not automatic, I rather do it manually as these events are really rare and I have a fixed IP on my primary ISP.
It’s just important to understand how/if redundancy might work.
Just a question: is qualification still deactivated for failed uptime checks?
If not, what is the downtime threshold?
I’m asking this question because I added a new virtual disk to my Storj VM and, due to an error in my config, the process takes very very long time (settings have been modified more than 3 hours and it did only 27%…).
