Data Usage Discrepancy Between Dashboard and Actual Storage
Hello Storj community,
I’ve noticed a concerning discrepancy between my node’s actual storage usage and what’s being displayed on the Storj dashboard. Let me share the details:
Dashboard Statistics:
  • Bandwidth Used This Month: 0.68TB
  • Average Disk Space Used: 128.22GB
  • Total Disk Space: 5TB
  • Currently Used: 469.3GB
  • Free Space: 4.51TB
  • Trash: 25.56GB
However, when checking my actual storage usage, I’m seeing significantly higher numbers:
  • Storage Used: 662.26 GiB
  • Total Available: 138.08 TiB
This represents a notable difference between the dashboard metrics and actual storage utilization. The pattern began around January 11th, as shown by the bandwidth utilization graph which displays a sharp increase in ingress traffic.
Questions:
  1. Is anyone else experiencing similar discrepancies between dashboard readings and actual storage usage?
  2. Could this be related to the recent increase in ingress traffic?
  3. What troubleshooting steps would you recommend to identify the root cause?
I would appreciate any insights or guidance on resolving this issue. I’m running this node on TrueNAS Scale
[Screenshots attached showing bandwidth utilization, storage metrics, and actual disk usage]
Thank you for your help in advance.
Hello @Barlog951,
Both are known issues:
Avg:
TL;DR
Avg cannot be fixed on the storagenode side, because it’s missing reports from the satellite. Unless you can solve this issue: Fix storage usage gaps displaying · Issue #7009 · storj/storj · GitHub
Total Used space:
This one has a workaround, but not a fix, see the topic.
Both issues do not affect your payouts.
