After updating to v0.31.9 I noticed this warning in the log (it probably was there before, but I did not notice it)
WARN piecestore:monitor Disk space is less than requested. Allocating space {"bytes": 3278521470976}
It is strange, because I have enough space on the drive:
Filesystem Size Used Avail Use% Mounted on
/dev/sda1 7.5T 4.2T 3.0T 59% /storj
There is only the node data on the disk and I have set 7200GB as the disk space in the node start command.
Does the node check for enough free space, while ignoring the space that it has used?
The node seems to work OK, just that this warning is weird.
