version: "3.3"
services:
<containername>:
container_name: <containername>
volumes:
- type: bind
source: <"/Path/to/identity/files">
target: /app/identity
- type: bind
source: <"/Path/to/Data/storage/location">
target: /app/config
ports:
- "28967:28967/tcp"
- "28967:28967/udp"
- 14002:14002
restart: unless-stopped
stop_grace_period: 300s
environment:
- WALLET=<WalletID>
- EMAIL=<Emailaddress>
- ADDRESS=<example.com:28967>
- STORAGE=<1TB>
watchtower:
image: storjlabs/watchtower
container_name: watchtower
command: "<containername> watchtower --stop-timeout 300s --interval 21600"
volumes:
- /var/run/docker.sock:/var/run/docker.sock
Thank you for update! I changed the first post to a wiki, so now you should be able to edit it.
The first yaml is now also updated. and there is a solution pinned.
If anyone needs help setting up his/her Docker container via docker-compose, just write me a message.
I am not around any day, but when i see the message, i’ll reply!
Is it possible to put multiple Dockers into one Docker-Compose?
Like a STORJ-Docker and a STORJ-Exporter-Docker? Can you tell about the auto/restart of the compose? When is the file beeing read and executed?
Yes, you can do it. Each container can have an own policy regarding restarts.
So if you specify, that it should be restarted, it will be restarted.
Yes, I do just that in my deployment.
