Being new to both Linux and Storj, and after having several issues with a Windows based storage node, I have started building a Linux Ubuntu node, installing the latest version of Ubuntu. I have just started the docker engine installation part of the process and I have come up with a bit of a issue. On the part of adding the repository for my version of Ubuntu, I realise that because the version I am using, the version of Docker I want is not available. I am guessing this is because this release of Ubuntu only came out last month?
Does any one have a solution on how I can rectify this issue? Can I install a different version of Docker or do I have to install a older version of Ubuntu? If I have to install a older version of Ubuntu, I am guessing that would mean moving all the keys over, of which I have not the experience with Linux yet to do that.
Do you have a guide / link to Docker CE I can read up on? As mentioned above, I am very new to Docker (first week of using it) and relatively new to Ubuntu / Storj
SO I went for it and used the Docker Engine bionic (Ubuntu 18.04 LTS) release file on my Ubuntu 20.04 LTS focal. So far, so good but having another issue now. I have made it all the way to the point in the CLI setup of âCheck the status of your nodeâ with what I feel is success so far but I am unable to check the status of my node through any of the means provided. I dont think it is related, unless anyone thinks different?
Thank you to @JoshGarza and everyone else for your help.
Iâll post a final update on how it goes with my current issue and if this solution works.
Show us the docker command you used to start your node (or the docker-compose.yml file if you started it that way). Also the output of docker ps would be helpful.
/dev/sdb is the actual hard disk as a device. Youâll need to partition it (which would create partition devices like /dev/sdb1), format the partition, and then mount that partition in /etc/fstab to something like /mnt/storj. Then youâd use /mnt/storj in place of /dev/sdb in your docker run command.
So another update to my installation. Its still not working. I have updated the destination location and then it said online for about a hour. It then said offline, I went to check again and now I have the following message 'Error response from daemon: Container (hidden information) is not running. The CLI dashboard doesnât work now, and the Storage Node Operator Web Dashboard has never worked, on any computer. Any help would be appreciated.
This says that the dashboard will only work on the local computer. It will also only work when the container is running i.e. in docker ps the status needs to be âupâ
You can tidy up your old hello-worlds with e.g. âdocker rm 12345â
