Does Graceful Exit require the port to be opened?
I’m selling my house and don’t have access to a public IP (CGNAT) and so I can’t port-forward like normal.
I think I’ll have to start a Graceful Exit, but I need to know if :29587 needs to be open inbound in order to sign out of the Storj network…
Thanks!
Why not opt for VPN with port forwarding service ?
Yes, access to the node through the port is required. You could use a VPN/VPS solution but you’d have to weigh the time/cost vs how much money is in your escrow.
Got any recommendations?
I’m not sure which one plays nice with Storj…
I tried multiple VPN’s with port forwarding and validated the port was open, but Storj still says offline
(Proton VPN and Portmap.io)
What is the secret to making this work?
Found the issue, public IP address got moved in the config file, disregard previous reply…
In case of portmap.io you can use their provided hostname instead of IP.
