Hello together,
right now when I download a storagenode it says ERROR 404: Not found:
Is there some problem with github or something?
Thanks and kind regards,
Likely the release 1.93.2 doesn’t exist at all. But how to switch back to 1.92.1?
Please help the node is offline. ![]()
@jtolio Can you please help and fix the release issues? It’s kinda urgent.
Restarting my node today resulted in this:
--2023-12-12 22:05:42-- https://version.storj.io/processes/storagenode/suggested/url?os=linux&arch=amd64
Resolving version.storj.io (version.storj.io)... 34.173.164.90
Connecting to version.storj.io (version.storj.io)|34.173.164.90|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 84 [text/plain]
Saving to: 'STDOUT'
0K 100% 223M=0s
2023-12-12 22:05:42 (223 MB/s) - written to stdout [84/84]
--2023-12-12 22:05:42-- https://github.com/storj/storj/releases/download/v1.93.2/storagenode_linux_amd64.zip
Resolving github.com (github.com)... 140.82.121.4
Connecting to github.com (github.com)|140.82.121.4|:443... connected.
HTTP request sent, awaiting response... 404 Not Found
2023-12-12 22:05:42 ERROR 404: Not Found.
downloading storagenode
--2023-12-12 22:06:34-- https://version.storj.io/processes/storagenode/suggested/url?os=linux&arch=amd64
Saving to: 'STDOUT'
0K 100% 223M=0s
2023-12-12 22:06:35 (223 MB/s) - written to stdout [84/84]
--2023-12-12 22:06:35-- https://github.com/storj/storj/releases/download/v1.93.2/storagenode_linux_amd64.zip
2023-12-12 22:06:35 ERROR 404: Not Found.
I rebooted and purged the docker image, but it didn’t work out.
Indeed the link mentioned in these messages doesn’t work.
Any other solutions?
I got exactly, the same problem…
Happens more often I see…
Seems to be same issue as here: ERROR 404: Not found while downloading storagenode (so this one actually can be closed).
Same issue here: Node on test net not starting due to missing file on github
So it seems the developer team need to fix this…
Essentially, the file https://version.storj.io/processes/storagenode/suggested/url?os=linux&arch=amd64 does show https://github.com/storj/storj/releases/download/v1.93.2/storagenode_linux_amd64.zip
This version apparently doesn’t exist, as can be seen by following the url.
I don’t understand, this URL seems to work: https://github.com/storj/storj/releases/download/v1.93.2/storagenode_linux_amd64.zip
Is this still happening for you? Perhaps some process just caught up in the last hour?
Than really just now, because it didn’t work even 15 minutes ago.
And indeed, the node it functioning again… Apparently the link exists since 22:15
Previously there were only 2 entries in 1.93.2 from you @jtolio .
Now its populated with more entries by the storjBuildBot:
Edit: It is also not Verified, but seems now to work:
Edit-2: There were only the two source code entries at the bottom:
Our robot must have been slow today. I’ll try and figure out what happened.
Thanks alot. ![]()
(just some text to fill 20 characters)
