Error: CA certificate and/or key already exists, NOT overwriting!
Hi I am trying to set up a 2nd node on my machine (windows 10) but am not sure how to generate a new identity without the below error appearing. Can anyone advise?
You need to create a new identity from scratch including requesting a new identity key. I don’t use Windows but somehow you’ll need to be able to run the identities side-by-side as a single identity is associated with a single node.
You can create identity on another computer and copy it to this computer to run multiple nodes
If you dont just simply delete the old identity you had, You can just run ./identity.exe create storagenode2 it will create a new folder just for this node and then you will need to authorize it the same way
./identity.exe authorize storagenode2 <email:characterstring>
I knew it was something simple like this lol thank you!
I’m installing a node on a Linux computer for the first time and got this error???
aurum@Rig-27:~ unzip -o identity_linux_amd64.zip Archive: identity_linux_amd64.zip inflating: identity aurum@Rig-27:~ chmod +x identity
aurum@Rig-27:~ sudo mv identity /usr/local/bin/identity aurum@Rig-27:~ identity create storagenode
I have no idea why or how to fix it.
aurum@Rig-27:/usr/local/bin$ ls -l
total 18452
-rwxr-xr-x 1 root root 6946 Aug 5 2019 apt
-rwxr-xr-x 1 root root 535 May 26 06:31 gnome-help
-rwxr-xr-x 1 root root 196 Feb 7 2019 highlight-mint
-rwxr-xr-x 1 aurum aurum 18864608 May 20 03:45 identity
-rwxr-xr-x 1 root root 243 Aug 30 2017 mint-sha256sum
-rwxr-xr-x 1 root root 964 May 15 2019 search
-rwxr-xr-x 1 root root 552 May 26 06:31 yelp
Edit: Scanned back through the command line history and see that I entered a single command, many commands ago:
aurum@Rig-27: ./identity_linux_amd64 create storagenode
Which makes no sense for two reasons: 1, I’ve successfully installed 7 nodes on 7 computers and 2, Rig-27 has a teeny tiny puny little 500 GB NVMe SSD that is not eligible to host a node. This time I’m trying to figure out how to attach three 3 TB HDDs and put nodes on them. I guess I need to delete the identity on this puny little bitty 500 GB SSD, mount the first 3 TB HDD and try again. Advice is welcome as I cannot find the instructions for my desired configuration. It’s surprising that a procedure for this is not included in the installation guide.
The identity binary creates identity with the specified name in the ~/.local/share/storj/identity folder.
ls -l ~/.local/share/storj/identity
If you have not moved the previous identity from there, it’s time to do it now.
Or you can use a different name not the storagenode
I’m now running identity for the third time. All 3 times
grep -c BEGIN ~/.local/share/storj/identity/storagenode1/ca.cert
grep -c BEGIN ~/.local/share/storj/identity/storagenode1/identity.cert
return ed 1 & 2 in stead of 2 & 3. The guide only says try again if it’s not 2 & 3.
And when I try to update my repositories I get:
Err:6 https://download.docker.com/linux/ubuntu bionic InRelease
The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY 7EA0A9C3F273FCD8
Reading package lists… Done
W: GPG error: https://download.docker.com/linux/ubuntu bionic InRelease: The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY 7EA0A9C3F273FCD8
E: The repository ‘https://download.docker.com/linux/ubuntu bionic InRelease’ is not signed.
N: Updating from such a repository can’t be done securely, and is therefore disabled by default.
Did you try to install docker according to this page? Install Docker Engine on Ubuntu | Docker Docs
Then you forgot step 2
curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo apt-key add -
Thanks, that was it for installing docker.
The major problem is why am I getting 1 & 2 instead of 2 & 3 ???
Tried it again and it’s still 1 & 2 instead of 2 & 3.
Surely this isn’t the first time this has happened.
What’s wrong???
It’s not authorized. Follow the instructions to authorize the identity with the token you received in your email.
https://documentation.storj.io/dependencies/identity#authorize-the-identity
Thanks, that fixed it…
Just came across this notification today, and can’t find a --forceDelete parameter so just in case for anyone else in the future or even my future self, the folder where the identity is:
C:\Users\YOUR_USER_NAME\AppData\Roaming\Storj
Just delete this folder and rerun the command.
But of course, first make sure your running node is not targeting this folder for finding its identity :slight_smile:
You can also just use a different name for the new identity.
identity create storagenode2
It will then create a new folder with that name for the new identity.
