ye its turned into a mess
Sweet reinstalled and working thank ye for your directions
This is because of missing setup step. In Windows GUI it’s done via reinstall, in docker - Storage Node - Node Operator
Noting on contact:service ping satellite failed??
ERROR piecestore
download failed
“error”: “context
deadline exceeded”
What is this one all about?
Variation of “Context canceled” - your node was too slow to give a piece.
I have an error:
ERROR collector error during collecting pieces: {"Process": "storagenode", "error": "database disk image is malformed"}
how can I figure out which database is malformed? I will delete it and restart node.
You can also search the forum
If you still get stuck make a separate thread about it. This is not the right thread for your issue.
I meant how to find which file is corrupted, or just remove all of them?
You may use a script from the above guide (depends on used approach and OS), it will check all databases one by one.
