Post your log between 3 backticks ```
Hello,
I got this error today (It happened only once) :
2021-03-11T17:02:11.121Z ERROR piecestore download failed {"Piece ID": "WY64G3BUUNWGA7QD2ZVY33HXSIQ3ZLBWFFD7R2RCOSLTE35FXRCQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET", "error": "file does not exist", "errorVerbose": "file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:74\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:506\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:1033\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:29\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:58\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:111\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:62\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:99\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51"}
The disk shows no error. The node never hung-up, just the regular Storj container upgrades restarts.
Is there something I need to worry about ?
All the best !
You lost the piece that is why it says “file does not exist”. Did you have a sudden restart or power outage ?
Nope, never. the node is on an UPS
How old is your node ? You can search your log when the piece was uploaded. Your hardware could have restarted a month back and this only showed up now when the piece was getting downloaded.
Hello,
Thanks for your reply.
The node is up from early January, but I cleared the log after the upload.
I’ve searched more into the log.
- A grep on the file returns this interesting entries :
| 2021-03-09T23:43:34.521Z | INFO | piecestore | download started | {“Piece ID”: “WY64G3BUUNWGA7QD2ZVY33HXSIQ3ZLBWFFD7R2RCOSLTE35FXRCQ”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET”} |
| 2021-03-09T23:43:35.479Z | INFO | piecestore | downloaded | {“Piece ID”: “WY64G3BUUNWGA7QD2ZVY33HXSIQ3ZLBWFFD7R2RCOSLTE35FXRCQ”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET”} |
| 2021-03-10T20:23:47.160Z | INFO | **collector | delete expired** | {“Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Piece ID”: “WY64G3BUUNWGA7QD2ZVY33HXSIQ3ZLBWFFD7R2RCOSLTE35FXRCQ”} |
| 2021-03-10T21:42:54.825Z | INFO | piecestore | download started | {“Piece ID”: “WY64G3BUUNWGA7QD2ZVY33HXSIQ3ZLBWFFD7R2RCOSLTE35FXRCQ”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET”} |
| 2021-03-10T21:42:54.873Z | ERROR | piecestore | download failed | {“Piece ID”: “WY64G3BUUNWGA7QD2ZVY33HXSIQ3ZLBWFFD7R2RCOSLTE35FXRCQ”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET”, “error”: “file does not exist”, “errorVerbose”: “file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:74\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:506\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:1033\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:29\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:58\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:111\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:62\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:99\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”} |
What’s interesting is that happening after the " delete expired " collector message yesterday.
- Then I greped on the “delete expired” string and I got many files from 4 to 11 March 2021, all from the EU West satellite.
So How a file which is supposed to be deleted is requested for download ? There is something that I don’t understand.
Hi, this is an expected behavior of the system.
There are a bunch of things that happen asynchronously, hence there’s some eventual consistency behaviors that might not be obvious at first sight.
Let’s take an example scenario that demonstrates it:
- At 11:15:00 Alice on computer A sends a request to download an object to the satellite, then satellite responds with the needed order limits for the specific storage nodes.
- At 11:15:01 Bob on computer B sends a delete request for that object, which ends up sending a delete request to the storage node. Storage node deletes the piece.
- At 11:15:03 Alice on computer A starts using the order limits (there was a latency spike on network, which caused it to take a bit longer)… however, now, none of the storage nodes have that data anymore.
This ends up in the logs as:
- object deleted
- download started
- download failed
With object expiration, the timeframe when this can happen is larger, because the satellite takes more time to delete expired objects/segments than the storage node.
Hello,
Thanks for the explanation. It’s clear now.
I was just worrying that something happens on my node potentially causing issue, especially for the GE process.
All the best !
./identity.exe authorize storejnode email:*****@gmail.com:1XtU1ovrtStgSavWMrZoRfmuZwGHdm1P7nyKDm3nxuerx9pPQcMb1YiaaBT6YUDPMnFWz5aX5622PFv9Szaxz4ZAywokex
Error: certificates peer error: authorization not found:
Did you have that text in the command ?
It should be
/identity.exe authorize storejnode abaig60156@gmail.com:1XtU1ovrtStgSavWMrZoRfmuZwGHdm1P7nyKDm3nxuerx9pPQcMb1YiaaBT6YUDPMnFWz5aX5622PFv9Szaxz4ZAywokex
Hi All
having trouble getting a second node open with this error after creating a node with the windows GUI. and using GUI Toolbox to open the second node. I am studying how multiple nodes function so I can master the software. This is the error I am getting
2021-07-02T19:52:28.856+1000 FATAL Unrecoverable error {“error”: “Error starting master database on storagenode: group:\n— CreateFile D:\blobs: The system cannot find the file specified.\n— CreateFile D:\temp: The system cannot find the file specified.\n— CreateFile D:\garbage: The system cannot find the file specified.\n— CreateFile D:\trash: The system cannot find the file specified.”, “errorVerbose”: “Error starting master database on storagenode: group:\n— CreateFile D:\blobs: The system cannot find the file specified.\n— CreateFile D:\temp: The system cannot find the file specified.\n— CreateFile D:\garbage: The system cannot find the file specified.\n— CreateFile D:\trash: The system cannot find the file specified.\n\tmain.cmdRun:162\n\tstorj.io/private/process.cleanup.func1.4:363\n\tstorj.io/private/process.cleanup.func1:381\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.Exec:65\n\tmain.(*service).Execute.func1:64\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
and the node is not writing anything to the data disk. I think the error involves storage path and Database2 path as I had no idea what to put in Database2. Can someone help me with putting the correct files back in please?
This is often a permissions problem writing directly into the root of a drive. Reinstall the node or adjust the config.yaml with the StorJ directory set to D:\Node or D:\Storj instead of the root of the D:\ drive.
2021-07-02T20:06:44.999+1000 FATAL Unrecoverable error {“error”: “Error starting master database on storagenode: group:\n— CreateFile D:\Storagenode1\blobs: The system cannot find the file specified.\n— CreateFile D:\Storagenode1\temp: The system cannot find the file specified.\n— CreateFile D:\Storagenode1\garbage: The system cannot find the file specified.\n— CreateFile D:\Storagenode1\trash: The system cannot find the file specified.”, “errorVerbose”: “Error starting master database on storagenode: group:\n— CreateFile D:\Storagenode1\blobs: The system cannot find the file specified.\n— CreateFile D:\Storagenode1\temp: The system cannot find the file specified.\n— CreateFile D:\Storagenode1\garbage: The system cannot find the file specified.\n— CreateFile D:\Storagenode1\trash: The system cannot find the file specified.\n\tmain.cmdRun:162\n\tstorj.io/private/process.cleanup.func1.4:363\n\tstorj.io/private/process.cleanup.func1:381\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.Exec:65\n\tmain.(*service).Execute.func1:64\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
still doing it after the rename
not sure what is going on here
What user is running the ‘storagenode’ service? Normally it would be ‘system’ , ‘local system’ or ‘network service’. The account which is running the service needs permissions to the D:\ drive. Also just checking you’re not using an SMB share? That’s not supported. It must be a local or iSCSI device.
Full control was not switched on for D: which i changed I started the node and for a second it went green and then went offline again. the error log is showing nothing now when I start the node and the node is not showing on localhost, thanks for your patience with inexperience
At this point I would probably clear the D:\ drive, uninstall and put the correct permissions in place before re-installing.
