First time here! Qnap NAS help with setting up a node
Hello all
I’m trying to setup a node using a Qnap NAS, but since the app doesn’t work i’m at a loss on how to proceed i already generated the key on my PC, installed some 3rd party app to run linux commands on the Qnap, also did a no-ip account and configured my home router, but i don’t know where to place my CA on the Qnap or what to do next.
Any help or a link to some more resources would be nice.
Hi @xtreamer
Try this
Is this it?
Thank you for the quick reply
how to reach those folders to copy my identify certificate?
You don’t have to use the qnap container, at least I didn’t use it. The docker will create itself with cli commands. You just have to create the folders in the qnap disk first. I connected with the pc and copied the identity…
This command only needs to be given once, otherwise you destroy the node
docker run --rm -e SETUP="true"
–mount type=bind,source="",destination=/app/identity
–mount type=bind,source="",destination=/app/config
then go of this
-p 28967:28967/tcp
-p 28967:28967/udp
-p 127.0.0.1:14002:14002
-e WALLET=“0xXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX”
-e EMAIL="user@example.com"
-e ADDRESS=“domain.ddns.net:28967”
-e STORAGE=“2TB”
I got it working thanks to @Roberto
:star_struck: :star_struck:
