GET_REPAIR failed because of invalid signature
Hi, I just got a notification that the audit score for my node is less than 1. Looking through my logs, I found this:
cat docker.00065.log | grep AUDIT | grep fail | wc -l
0
cat docker.00065.log | grep AUDIT | grep started | wc -l
5187
cat docker.00065.log | grep AUDIT | grep downloaded | wc -l
5187
 cat docker.00065.log | grep REPAIR | grep fail | wc -l
4
So, audits seem to be OK, but there are failed repair downloads, which I know also affect audit score.
2021-11-12T08:23:11.814Z        ERROR   piecestore      download failed {"Piece ID": "3AUGAI7MMFTKWGQOWMBO5TMPGC6ZYPHR7F466JXJOITAZ5CBI5JA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_REPAIR", "error": "signing: piece key: invalid signature", "errorVerbose": "signing: piece key: invalid signature\n\tstorj.io/common/storj.PiecePublicKey.Verify:67\n\tstorj.io/common/signing.VerifyUplinkOrderSignature:60\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).VerifyOrder:102\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func6:663\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:674\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:228\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:58\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:104\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:60\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:97\n\tstorj.io/drpc/drpcctx.(*Tracker).track:52"}
2021-11-12T08:23:11.897Z        ERROR   piecestore      download failed {"Piece ID": "ZSYW6HKR2WZ7GZI7I3MXU42HH45LNJU6L7COGCSBH2WOJGLI5XHQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_REPAIR", "error": "untrusted: invalid order limit signature: signature verification: signature is not valid", "errorVerbose": "untrusted: invalid order limit signature: signature verification: signature is not valid\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).VerifyOrderLimitSignature:145\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).verifyOrderLimit:62\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:490\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:228\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:58\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:104\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:60\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:97\n\tstorj.io/drpc/drpcctx.(*Tracker).track:52"}
2021-11-12T08:50:00.313Z        ERROR   piecestore      download failed {"Piece ID": "4SGNT6DEUVKQTDAQ5D7KRM5TZS4HAHHXV3OSAM3C4WHZTRY25VIQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_REPAIR", "error": "untrusted: invalid order limit signature: signature verification: signature is not valid", "errorVerbose": "untrusted: invalid order limit signature: signature verification: signature is not valid\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).VerifyOrderLimitSignature:145\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).verifyOrderLimit:62\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:490\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:228\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:58\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:104\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:60\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:97\n\tstorj.io/drpc/drpcctx.(*Tracker).track:52"}
2021-11-12T09:06:15.098Z        ERROR   piecestore      download failed {"Piece ID": "RCXFOOKE2QDD5TF4HDOGZ2JI4HIEYNHP7ETWBSKIHNHDFROVMUWA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_REPAIR", "error": "untrusted: invalid order limit signature: signature verification: signature is not valid", "errorVerbose": "untrusted: invalid order limit signature: signature verification: signature is not valid\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).VerifyOrderLimitSignature:145\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).verifyOrderLimit:62\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:490\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:228\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:58\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:104\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:60\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:97\n\tstorj.io/drpc/drpcctx.(*Tracker).track:52"}
What is the cause of this and how can I fix it? I checked, server time seems to be synced with ntp servers.
I will monitor this closely and will shut my node down if this happens again to prevent DQ.
searched forum for signature is not valid.
this seems to have the same issue, the solution i guess was to pull the docker image again.
ofc you are on zfs, with redundancy so the possibility for the image being the case is minimal.
I have removed and pulled the image again, we’ll see.
I do not think it’s the same problem because in the post, the node refuses to start, while my node starts and runs, but also fails some repair downloads.
It’s only on eu1 satellite (at least for now). Interestingly, I also got two PUT_REPAIR failures, also on the same satellite:
2021-11-12T09:15:43.800Z        ERROR   piecestore      upload failed   {"Piece ID": "7URJKIBTD6DFRJ22QCU3T4G7ADDGISZWA3EFPEABZYYGSKZWPYPA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "PUT_REPAIR", "error": "hashes don't match", "errorVerbose": "hashes don't match\n\tstorj.io/common/rpc/rpcstatus.Error:82\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).VerifyPieceHash:120\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:385\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:220\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:58\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:104\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:60\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:97\n\tstorj.io/drpc/drpcctx.(*Tracker).track:52", "Size": 2319360}
2021-11-12T09:16:45.025Z        ERROR   piecestore      upload failed   {"Piece ID": "GIUYP4BYK3HZBZOLLGMYYQJDUH5YFCRCEXTLBAIGPKOJ2V2PEKZQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "PUT_REPAIR", "error": "hashes don't match", "errorVerbose": "hashes don't match\n\tstorj.io/common/rpc/rpcstatus.Error:82\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).VerifyPieceHash:120\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:385\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:220\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:58\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:104\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:60\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:97\n\tstorj.io/drpc/drpcctx.(*Tracker).track:52", "Size": 2317056}
i actually have 2 nodes which has a slight drop in suspension score… guess a satellite…
i guess i should try and check what that is about…
2021-11-12T08:49:28.341Z        ERROR   piecestore      download failed {"Piece ID": "EHMDRZJVMGVW2SWD7D3EC3AKADUBCERDZHZATIIREPDD37CYXNDQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_REPAIR", "error": "untrusted: invalid order limit signature: signature verification: signature is not valid", "errorVerbose": "untrusted: invalid order limit signature: signature verification: signature is not valid\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).VerifyOrderLimitSignature:145\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).verifyOrderLimit:62\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:490\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:228\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:58\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:104\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:60\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:97\n\tstorj.io/drpc/drpcctx.(*Tracker).track:52"}
2021-11-12T09:05:05.153Z        ERROR   piecestore      upload failed   {"Piece ID": "BBJL2SSQMPHJI7X5J6HPCE6UJS6BW7EB27M6PXIE4XBZYRFA7NPA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "PUT_REPAIR", "error": "hashes don't match", "errorVerbose": "hashes don't match\n\tstorj.io/common/rpc/rpcstatus.Error:82\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).VerifyPieceHash:120\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:385\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:220\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:58\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:104\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:60\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:97\n\tstorj.io/drpc/drpcctx.(*Tracker).track:52", "Size": 2317056}
2021-11-12T10:22:46.666Z        ERROR   piecestore      upload failed   {"Piece ID": "3VOTPWQSK47H4SDOTXHSZSJONRRZOKUX5JC5AX63YRD6JKUGXUDQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "PUT_REPAIR", "error": "signing: piece key: invalid signature", "errorVerbose": "signing: piece key: invalid signature\n\tstorj.io/common/storj.PiecePublicKey.Verify:67\n\tstorj.io/common/signing.VerifyUplinkOrderSignature:60\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).VerifyOrder:102\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:355\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:220\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:58\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:104\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:60\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:97\n\tstorj.io/drpc/drpcctx.(*Tracker).track:52", "Size": 1843200}
2021-11-12T11:13:37.504Z        ERROR   piecestore      upload failed   {"Piece ID": "FP4KXZH3HMUDPF6GVUTWUDPNRVY4IS4DEWTJ5HCWS4RARK32HG5A", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "PUT_REPAIR", "error": "hashes don't match", "errorVerbose": "hashes don't match\n\tstorj.io/common/rpc/rpcstatus.Error:82\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).VerifyPieceHash:120\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:385\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:220\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:58\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:104\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:60\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:97\n\tstorj.io/drpc/drpcctx.(*Tracker).track:52", "Size": 2317056}
2021-11-12T11:23:41.453Z        ERROR   piecestore      upload failed   {"Piece ID": "RBGPGTLOWM5TJPDUEYKFGRM5IWF2JPWRLPUPSREUCJSMN4IJDV6A", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "PUT_REPAIR", "error": "hashes don't match", "errorVerbose": "hashes don't match\n\tstorj.io/common/rpc/rpcstatus.Error:82\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).VerifyPieceHash:120\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:385\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:220\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:58\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:104\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:60\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:97\n\tstorj.io/drpc/drpcctx.(*Tracker).track:52", "Size": 2317056}
seems like we are seeing the same thing.
@Alexey this seems weird, kinda makes me wonder if this was what caused my other drops in suspension score, even tho i didn’t manage to find the cause.
Same on my node same sat
Another node
This appears to be a wide issue not a single node but every single node I have 5 nodes with the same issue.
2021-11-12T09:05:04.950Z        ERROR   piecestore      upload failed   {"Piece ID": "Y7GWIJUYPUTUX4G7DZILQNHNJEG6P2C53BPABBAYRU4V2IZ62FVQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "PUT_REPAIR", "error": "hashes don't match
2021-11-12T08:23:14.085Z        ERROR   piecestore      download failed {"Piece ID": "3CDJYXWGSZ6SVEY5QHKZVJEDGCAOF6IMVFFDR4AF3HUROUF72T2A", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_REPAIR", "error": "untrusted: invalid order limit signature: signature verification: signature is not valid", "errorVerbose": "untrusted: invalid order limit signature: signature verification: signature is not valid
I’ve checked my logs, this issue seems to have started today 2021-11-12 older logs a week back has no such entries.
This seems like it could be a serious issue long term, my best guess would be something like a security certificate has run out on the EU1 sat
@bre @Knowledge @littleskunk
The same problem on different nodes
Thank you for alerting us @SGC
I’ve forwarded this to the team.
Yep, seeing the same thing now as well. No need to repeat screenshots and errors as they are the same. But I would like to note that it seems the repair workers seem to be sending bad requests to nodes and nodes are penalized for rightfully rejecting them.
At the moment I’m not too worried about serious consequences as this only hits the suspension score, so at the worst nodes will get suspended, not disqualified. However, we’ve seen similar issues escalate in the past and increase in frequency. If that happens here and a significant number of nodes get suspended, that could still impact data availability.
Sucks that this is happening on a friday :frowning: hopefully it isn’t going to eat into peoples weekends. Let us know if we can do more from our end to aid the bug hunting.
It seems that this has hit both scores on my node, at least for a short time.
There are no “real” audit failures and the count of “download started” and “downloaded” lines for audits is equal, so no timeouts either.
The scores have recovered, at least for now, and the last error in the log is this:
2021-11-12T13:03:29.021Z        ERROR   piecestore      upload failed   {"Piece ID": "NWCY6Q6536MQN2UNL2EYLI7CN4PNCOKNKVCS4NCGFENNHY7DD3KA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "PUT_REPAIR", "error": "hashes don't match", "errorVerbose": "hashes don't match\n\tstorj.io/common/rpc/rpcstatus.Error:82\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).VerifyPieceHash:120\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:385\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:220\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:58\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:104\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:60\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:97\n\tstorj.io/drpc/drpcctx.(*Tracker).track:52", "Size": 658176}
Maybe this was a transient problem. I don’t like that it affected the audit scores though.
You need also to measure time between them…
The node report as download finished, even if it has timeout…
See
As far as I know (or rather, what my script says), the longest interval between “download started” and “downloaded” for GET_AUDIT is 1.57 seconds for that satellite (a bit over 2 seconds overall). For GET_REPAIR on that satellite it’s 4.44 seconds.
There are two GET_REPAIR error types:
and
Maybe one of them affects unknown audits and the other normal audits?
i was told that if one get suspended and then goes above 60% then the sat will DQ for going below 60% suspension score within the next 30 days or so…
so atleast it seems moderate and suspension score recovers fairly fast so thus far it doesn’t seem dangerous…
but might be over pretty quick if one did get into suspension, because it would bounce right back and then possibly go below again…
You’re confusing it with the uptime suspension. There if you are suspended fore uptime below 60% you get 7 days to fix any issues, then a 30 day monitoring period starts and if uptime is not above 60% at the end of that period, you get disqualified.
As far as I’m aware there is no permanent disqualification as a result of a dropping suspension score.
Me neither, that is a bit more serious… At least they are still infrequent enough that we’re not getting anywhere close to any DQ/Suspension consequences.
you are right. i am lol
Getting that SMS was not fun, but at least it seems to have stopped. Getting my node disqualified because of a bug in the code (if this turns out to be a bug), now that would be awful.
Based on history I’m certain it would be reinstated if it was really due to a bug or satellite misconfiguration.
Could be, my node is v1.42.4
also on 1.42.4 here… and did update 49 hours ago
and only seeing it in the last 20 hours… also not all nodes seems to be affected.
so i don’t think it’s the update, but its ofc possible.
Our devs are currently troubleshooting this issue. Thanks for making us aware of it.
