Hi all!
I am trying to monitor my node on windows.
I have:
Node fully running
Installed grafana
Got prometheus
Also i have docker but i can’t manage to understand how to work with it!
But since i understand ZERO of coding / commands and since it is a little confusing for me, it is difficult to install the monitoring with prometheus and / or grafana and / or storj prometheus exporter.
Does anyone want to help me create a monitoring tool of my node?!
I just need the correct steps so i can try work it out… even on docker.
Many thanks for your time!
