I’ve noticed this evening my connection is getting hammered with ingress at a rate of 6gb a day and 2gb of repair bandwidth is the repair bandwidth coming from nodes leaving the network or something wrong on my end?
Sounds pretty low in terms of ingress 30gb with 4 gb repair here. 100/40 mbits connection.
60+gb/day also was normal someday back
The repair service is used not only to repair a lost data, but also for geofencing requests.
So all system’s normal then. Thank you.
I dont see that node amount is dropping lot, almost nothing, but may be GE takes time.
I read a post that nodes have went down by 20%
we near 21,9k nodes, only around 200 nodes go down.
I was referring to this Reducing the number of nodes in the US by almost 20% since May
US is not all the world, it is only small part.
