I searched from a lot of online documents on how to configure a firewall for a storj node but i didn’t find nothing, is there a port list or something else ?
When i launch docker et close my ssh session is, Docker still runing on background ?
Make an inbound rule to allow any traffic from the any source to the TCP 28967 port and your PC with a Docker as a destination.
If you have any restriction rule for outbound, then make an outbound rule to allow any traffic from any port of your PC to the any host with any port as a destination.
This is a general Linux question for sure.
The command to allow the TCP 28967 is sudo ufw allow 28967/tcp
To allow the outgoing traffic: sudo ufw allow from 64.63.62.61, where 64.63.62.61 is your local IP
