Can we mark as solution two topics?
For example, one topic answer to two questions and the other answer to remained question
Solution #1 (number one)
Solution #2 (second solution)
- See also
- reply #10 How to mark a two posts as solution?
- reply #5 How to mark a two posts as solution?
I have wondered the same thing myself. @Alexey what happens if you mark Solution #2 (above) as “solved”?
Basically I am wondering if our votes for solution carry equal weight. Or if it goes sequentially
It will switch them between each other
We must be equally weighted then, interesting!
but also kind of annoying, for the original problem
I think (and I know this is kludgy) that maybe we need to pick one top answer + add a link to the second answer via edit mode. I know this is definitely not perfect…
