plase help i just recently make node for 2 terabyte but then its offline and it says 1514251 hour running but its just started and all of the 100% all zeros please help I’m in the Philippines
Hello @marangkas18,
Before you will try to remove the node, its data and start from scratch, we need to figure out, why is it offline.
First of all, go through a checklist:
And the one thing i just created my storj identity and successfully created and i dont know what to do with the port forwarding so i resumed after a week is it affects the identity that i created?
Do i need to format my pc?
If you uninstall the storage node software, you need also to remove "c:\Program Files\Storj" before install.
no, unless it was online at least once (I assume it’s not).
no
You also do not need to reinstall in a first place. But since you already did, to install it back you need to remove artifacts from a previous install, i.e. remove the "c:\Program Files\Storj" folder.
It doesn’t look correct. You need to configure a port forwarding rule not the trigger port rule, unless your router doesn’t allow to use port forwarding rules without port triggering.
Please show the last 20 lines from your logs. Copy the text, please and paste it here between two new lines with three backticks, like this:
log lines here
Where to find log sir
What’s in the IPv4 port mapping section?
please use this guide: How do I check my logs? - Storj Docs
you need to compare this IP with WAN IP on your router
ERROR contact:service ping satellite failed {“Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “attempts”: 7, “error”: “ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 120.29.88.169:28967: connect: connection timed out”, “errorVerbose”: “ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 120.29.88.169:28967: connect: connection timed out\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:145\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:100\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75”}
Please find the WAN IP on the status page of your router and compare with IP on yougetsignal.
I see, this port mapping is port forwarding, but very weird.
Yes, this is safe to post this picture here. But you can mask a public IP in your logs.
Please clean trigger ports there:
If it would not allow to leave them empty, then provide the same 28967 in both fields.
Hello sir how to reach you sir this site has limited reply its me sir
either read more posts here on the forum, related to “offline”, or send me a DM, using your previous account.
