I am getting an error and i dont know what to do can anyone help
FATAL Unrecoverable error {“error”: "filewalker: CreateFile S:\blobs\qstuylguhrn2ozjv4h2c6xpxykd622gtgurhql2k7k75wqaaaaaa\gn\vdho45u73sfbenueetrmzvrh2ijdmkxpdm54lmrlbahm3itpfa.sj1: The file or directory is corrupted and unreadable.;
You should run your disk and filesystem program to check for errors.
wich filesystem are you using. hope its ntfs.
You need to stop the node and run chkdsk
try to check your s.m.a.r.t data also
and Welcome to the community!
