I changed ISP and cant get my nodes running
Hey all. I changed ISP today and payed for a static IP. The ISP told me this:
Be aware that you will still get an Internal IP on your equipment, which is statically NATed to your external IP.
So what i did was give my machine (the pc) a static ip: 192.168.0.199
I then port forwarded 192.168.0.199 to 28968 ~ 28968. So the port forward “should” work right?
My public static ip is: 83.89.251.1xx
So my Storj launch setting is:
docker run -d --restart unless-stopped --stop-timeout 300 -p 28968:28967/tcp -p 28968:28967/udp -p 127.0.0.1:14003:14002 -e WALLET=“XX” -e EMAIL=“XX” -e ADDRESS=“83.89.251.1xx:28968” -e STORAGE=“10TB” --mount type=bind,source=“C:\Users\andre\AppData\Roaming\Storj\Identity2\Identity\storagenode”,destination=/app/identity --mount type=bind,source=“E:\StorjData”,destination=/app/config --name storagenode storjlabs/storagenode:latest
But the node is still misconfigured and my port remains closed.
Is there something i dont understand or that im missing?
Im well on the way to get disqualified - so kinda need to be quick and i am very much stuck.
Thanks in advance
You mean port forwarded 28968 to 192.168.0.199:28968 right?
Correct- now the new ISP server is down - so this might be on their end. I do belive i did everything correctly?
How many days/hours can i be “offline” before being disqualified?
About 10 days when it will start to make problems (online score less than 60%) so you should have enough time to resolve it.
Okay - sounds good! thanks alot
Make sure, your new ISP does not use CGNAT. Then you need another solution like a VPN.
Okay - ISP is working and i have internet again. I was able to setup my node on the new ip on my pi4 - but still no luck on my windows pc? any ideas?
Here is the last lines of the log:
2022-12-01T23:15:54.238+0100 FATAL Unrecoverable error {“Process”: “storagenode”, “error”: “server: listen tcp :28967: bind: Only one usage of each socket address (protocol/network address/port) is normally permitted.”, “errorVerbose”: “server: listen tcp :28967: bind: Only one usage of each socket address (protocol/network address/port) is normally permitted.\n\tstorj.io/storj/private/server.New:91\n\tstorj.io/storj/storagenode.New:379\n\tmain.cmdRun:210\n\tstorj.io/private/process.cleanup.func1.4:377\n\tstorj.io/private/process.cleanup.func1:395\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfigAndLogger:92\n\tmain.main:478\n\truntime.main:250”}
2022-12-01T23:17:18.222+0100 ERROR contact:service ping satellite failed {“Satellite ID”: “12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo”, “attempts”: 11, “error”: “ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 86.52.59.183:28967: connect: connection timed out”, “errorVerbose”: “ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 86.52.59.183:28967: connect: connection timed out\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:145\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:100\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75”}
2022-12-01T23:17:23.127+0100 ERROR contact:service ping satellite failed {“Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “attempts”: 11, “error”: “ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 86.52.59.183:28967: connect: connection timed out”, “errorVerbose”: “ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 86.52.59.183:28967: connect: connection timed out\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:145\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:100\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75”}
2022-12-01T23:21:48.984+0100 ERROR contact:service ping satellite failed {“Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “attempts”: 12, “error”: “ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 86.52.59.183:28967: connect: connection timed out”, “errorVerbose”: “ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 86.52.59.183:28967: connect: connection timed out\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:145\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:100\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75”}
2022-12-01T23:28:00.601+0100 ERROR contact:service ping satellite failed {“Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “attempts”: 12, “error”: “ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 86.52.59.183:28967: connect: connection timed out”, “errorVerbose”: “ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 86.52.59.183:28967: connect: connection timed out\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:145\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:100\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75”}
2022-12-01T23:31:59.380+0100 ERROR contact:service ping satellite failed {“Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “attempts”: 12, “error”: “ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 86.52.59.183:28967: connect: connection timed out”, “errorVerbose”: “ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 86.52.59.183:28967: connect: connection timed out\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:145\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:100\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75”}
2022-12-01T23:32:22.830+0100 ERROR contact:service ping satellite failed {“Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “attempts”: 12, “error”: “ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 86.52.59.183:28967: connect: connection timed out”, “errorVerbose”: “ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 86.52.59.183:28967: connect: connection timed out\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:145\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:100\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75”}
2022-12-01T23:36:39.966+0100 ERROR contact:service ping satellite failed {“Satellite ID”: “12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo”, “attempts”: 12, “error”: “ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 86.52.59.183:28967: connect: connection timed out”, “errorVerbose”: “ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 86.52.59.183:28967: connect: connection timed out\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:145\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:100\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75”}
2022-12-01T23:36:45.836+0100 ERROR contact:service ping satellite failed {“Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “attempts”: 12, “error”: “ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 86.52.59.183:28967: connect: connection timed out”, “errorVerbose”: “ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: dial tcp 86.52.59.183:28967: connect: connection timed out\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:145\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:100\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75”}
Are you sure your IP have not changed?
My public IP usually changes after a router reboot, or hiccup on my ISP network.
My recommendation is to use a DDNS service.
My IP does not change - i paid for that. also whatsmyip is allways reporting the same.
He said: he got a fix IP
Is your RPI4 operates on a different port? Correct?
Shit just got weird. I removed my docker container for node number 2 (to focus on node 1 on windows gui). Then i rebooted and now the windows gui node is online but misc but still getting data.
yes - my windows pc has 2 nodes - one on docker and one on GUI - they used port 28967 and 28968
Correct - pi is 28969 so no problem there
Stop all malware protection in your router, if you have any… usualy from Trendmicro.
I had problems when I tried to use the same port 28967 to more than 1 node. Maybe you can try using different ports for each node, even in the docker run command, like 28968:28968 tcp and udp.
Well on my router i AM using different ports:
ip 198.168.0.199 is the windows machine
Use the same pairs in docker run command. And clear browser cookies, CTRL + F5, etc.
Sorry but what do i need to change here?
docker run -d --restart unless-stopped --stop-timeout 300 -p 28968:28967/tcp -p 28968:28967/udp -p 127.0.0.1:14003:14002 -e WALLET=“XX” -e EMAIL=“XXXX” -e ADDRESS=“83.89.251.XXX:28968” -e STORAGE=“10TB” --mount type=bind,source=“C:\Users\andre\AppData\Roaming\Storj\Identity2\Identity\storagenode”,destination=/app/identity --mount type=bind,source=“E:\StorjData”,destination=/app/config --name storagenode storjlabs/storagenode:latest
docker run -d --restart unless-stopped --stop-timeout 300 -p 28968:28968/tcp -p 28968:28968/udp
This part…
I just tried and still get the same error. :frowning:
