Hi , here is my marching and there one node is runing in 2TB HDD … and i have another 2TB HDD … how can i use it ? any suggection or advice ?
When your H: drive becomes full (considering you kept 10% as overhead) you can start another node on the other 2TB drive D:
how i can do that ? to run software again ? could you please explain it ?
Got it . tel me which port i should change when i install another node ? and how to do it ?
28967 or 14002
Read this, it will help you understand the parameters a lot better
You would be using custom port. Documentation shows how to use it.
You should use different port for dashboard too which can be achieved by
-p 127.0.0.1:14003:14002
OK 127.0.0.1:14003:14002 will be dashbord port and 28967 this port should be same as its connect storj network . ok i got it …not my currant HDD full and remind 20% more … ill wait will it come to 10% and run other-node
If you are using a custom port other than 28967, you have to change the -p 28967:28967
to -p <port>:28967
like 28968:28967
