Hello there
I’m curious that if it will be a huge different if I upgrade my internet speed from 1gb to 5gbs?? Does anyone tested it ever??
I do not think it makes a difference as long you have enough free bandwith.
Exactly, will not have an impact / a benefit. Especially when you need to invest for it.
The bandwidth difference for 1Gbps compared to 5Gbps would not make any difference to your node at the current network usage.
You can use the successrate script to check if you could be winning more races - Success rate script - Now updated for new delete terminology since v1.29.3. If you are losing races then further investigation would be required to find out exactly what methods could be used to improve the performance.
I have 168 TB of Storj data and have only 300/300 connection, working perfekt no need more.
Max i seen was 225 Mbit upload for short time this month. So connection is not botleneck
together it is 300/300, but yes it is more than 1 connection.
good mikrotic router handle boath connections.
168 TB in one network?
How many decades have been an SNO?
