Fast upload bandwidth has the potential to greatly impact earnings for storage node operators.
Numbers behind suspension, audit, “online” calculation, are quite well documented, transparent and clear.
But how about internet speed? How exactly does storj evaluate my node’s speed and what is the impact when choosing whether to store it here or on some other node? Are there any speed checks being performed to determine it? Or does it purely rely on the “race” when whether my node is fast enough to store/provide piece first or falls into “download/upload failed” once someone else is faster?
The answer to this one answers all your other questions as well. Yes, it purely relies on the race conditions. But you don’t lose just cancelled and failed uploads, you also lose many uploads that display as finished in the logs. From my experience, the impact of those less visible losses is probably higher than the ones that are visible. This happens if your node finishes the transfer before it receives the cancellation message, but still wasn’t among the 80 fastest nodes. And it’s very common.
Due to an unfortunate SSD failure I’m temporarily running 4 nodes on the same array without an SSD cache (this is a very bad idea, don’t do it) and I can see this effect happening due to lagging write performance on my nodes. Trash is much higher and the nodes barely fill up anymore. I have ordered new SSDs to resolve this asap (hopefully this weekend).
Because it’s a race against other nodes, it’s hard to exactly quantify the impact. There isn’t a set speed I can tell you after which you start to lose races. And as per my case above, this isn’t solely dependent on connection speed. It’s latency + throughput + IO performance + system overhead (CPU IO wait queue for example). But my unfortunate issue is starting to make it very clear that having bad performance in the upload chain has a big impact on how much data you get to keep on your node.
Very interesting!
You mean you have a ssd-read-write Cache for all your nodes?
Do you have some Numbers (e.g. the payout per tb/stored/month) with and without the Cache?
Or do you have only the Databases on a SSD?
I used to have 4 nodes running entirely on the SSD cached array + 8 more nodes on external HDDs for which the databases were on that array as well. I have since moved those databases the the individual node disks to alleviate some of the write load on the array now that it doesn’t have an SSD cache anymore.
The most telling numbers I can share is that my trash on larger nodes (3TB to 20TB per node for different ones) has gone up from always around 60GB to 180-200GB. Meaning I have more than 120GB trash on top of what I used to have. This means I’m losing 120GB MORE from ingress than I used to. Since trash is deleted after a week, that means losing out on about an additional 500GB of ingress per month, which is about 2/3rds, since last month I had 750GB ingress total on my main node. Needless to say, my setup is not exactly optimal at the moment, hence why I’m trying to fix that as soon as possible.
Considering that about 15% of data ingress each month also gets egress, that amounts to a loss of about 75GB on egress as well. So yes, bad ingress performance can have a big impact on payouts.
Do you have any ‘control’ nodes? Your ‘trash’ experience from the last month or so has been very similar to my node storing 16TB. Could it just be the current network usage? as my node never had an SSD cache
I have the same trash experience this month as well. Two spikes of 3 times and almost 4 times the amount i normally have across all nodes (individual HDDS no cache). Ive also made no changes this month. (I exited most satellites in november, but did not experience the trash increase until this month so I consider it unrelated) Plus ingress has been lower.
How do your cached nodes do against your uncached nodes? Success rates and general growth rates? Im curious how much an ssd cache helps nodes on individual HDDs vs the cost of the ssd and its wear as cache.
I can say that my external and internal nodes used to perform quite similar, but the external nodes weren’t entirely uncached since their db’s were on the cached array. I haven’t really checked the numbers because I didn’t split up the log files before and after the cache failure, but I can easily tell from just following the logs that I have a lot more cancelled transfers now than I used to have.
