When try
FATAL Unrecoverable error {“error”: “error occurred while signing certificate: rpc error: code = Internal desc = certificates peer error: error claiming authorization\n(identity files were still generated and saved, if you try again existing files will be loaded)”, “errorVerbose”: “error occurred while signing certificate: rpc error: code = Internal desc = certificates peer error: error claiming authorization\n(identity files were still generated and saved, if you try again existing files will be loaded)\n\tmain.cmdAuthorize:212\n\tstorj.io/storj/pkg/process.cleanup.func1.2:275\n\tstorj.io/storj/pkg/process.cleanup.func1:293\n\tgithub.com/spf13/cobra.(*Command).execute:762\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:852\n\tgithub.com/spf13/cobra.(*Command).Execute:800\n\tstorj.io/storj/pkg/process.Exec:74\n\tmain.main:83\n\truntime.main:203”}
