So I recently setup a Golem node again and even though it is currently very small I’ve actually been getting tasks.
Golem makes an interesting comparison with Storj as they support both zksync and polygon but they are moving primarily FROM zksync with polygon now being the main payment method.
I only have two wallets currently and one supports polygon and one supports zksync but I don’t think I can have both setup at the same time on my node - so that’s fun.
The reason for the move seems primarily due to cost with Polygon being much cheaper. So much so that they use micropayments and payments after a task is completed are pretty much instant.
I can’t do a financial comparison yet as my node is far too small (I’m only sharing 6 threads so far and I only have 4GB RAM on the node) and I need to play around with pricing more but as I expand the resources over time I’ll update here.
I like the application very much. It’s simple to run. And if the price is set low enough*, you get work. Payment is immediate. It’s really neat. And what I imagined micropayments and microservices to be…
I also like that their documentation includes a Blender 3D modeling output as their target example application.
*The default setting of 0.1 GLM is three orders of magnitude too high to get work… apparently. I don’t think I’m going to make any money renting out CPU time at such a low rate, but it’s fun anyway.
Just an update. After getting a firmware update done I’ve managed to get a second cpu installed to give me another 8 threads. I’ve also moved 32GB of ram from another server to this one. It will be interesting to see if the improved specs have any impact on how much work I get.
Sadly my server is now down with a hard red LED error. Will need to do some debugging. First thing to do will be to remove the new CPU. I’ve had faulty cpu’s from ebay sellers previously.
If you dial down the resources available to Golem and set the price just a bit lower than the lowest price shown on their network stats page… you should get a steady stream of work that pays about $0.15/day or so…
