Log Ingestion and Analysis with Graylog
For a while now I have been ingesting my Storj docker logs into Graylog for longer term retention and analysis and figured that there are probably some other SNOs who can benefit from a Storj specific configuration guide. I am sure I will have missed stuff, so if I have, please let me know. I will try to assist with issues where possible. Keep in mind that Graylog can use a decent amount of RAM and storage space over time, which can be reduced by reducing the number of logs being retained, which will be covered at the end.
Example of the end result:
NOTE: This stops the logs from being stored in the container so scripts like audit_success and successrate will no longer work as they are run against the logs stored on Docker. There are lots of analysis and visualization capabilities in Graylog, some of which I will cover in this initial post and update as I build out more to replicate as much as possible from the community scripts.
This guide assumes that you already have a working Graylog installation. You do not need to be ingesting data before proceeding with this though, this guide will cover setting up log ingestion. Setting up Graylog is pretty straightforward, the guides for doing so can be found here. There are definite improvements that can be made to this guide, it is essentially just the barebones to get SNOs going for analyzing their Storj logs. I encourage anyone implementing this to play around with the application as there is a lot of functionality to be leveraged with it.
After having logged into the Graylog web interface, we first need to set up a data input.
In the “Select input” field, search for and select “GELF UDP” and clink “Launch new input”
In the newly opened window, open the “Select Node” dropdown menu and select the Graylog server. Enter a title in the Title box. All other default settings should be sufficient for this data input. Once filled out select “Save” from the bottom. There should now be a GELF UDP input in the Input screen. Click “Start input” on the right side if the input is not running.
Next we will need to set up extractors. By default the logs ingested by Graylog will not be breaking the ingested data down into fields that can be indexed, so any analysis will be done against the entire log message string from each log entry which is slower and makes visualizations such as graphs not possible for comparing multiple types of messages. Click “Manage extractors” for the newly created input.
I have already gone through the trouble of building extractors for this work. Also thanks to initial work @Alexey (and @storjio68943 from the old Rocket Chat) did for his Logstash implementation. I updated the GROK queries for Graylog and the latest version of storagenode software. This covers the majority of types of log messages that Storj will generate, but please let me know if there are any additions you would like to see. From the Extractors page, select “Import extractors” and copy/paste all of the below text to import the JSON for all of the Extractors and then click “Add extractors to input” on the bottom left
With the extractors in place to start indexing incoming data, that should be all that is required for Graylog to start ingesting your logs. Next, your docker run command will have to be updated to redirect your logs to the Graylog server. The docker run command will require two additional flags:
–log-driver gelf
–log-opt gelf-address=udp://1.2.3.4:12201
The first line is telling Docker to use the GELF driver to output the logs in GELF format which includes some extra information about the host and container which is useful for filtering in Graylog. The second flag will have to be updated to be the IP address of the Graylog server (replace 1.2.3.4 with the IP of the Graylog server, change the port if you did not use the default port in the input configuration). In order to apply this the storage node container will have to be stopped and removed then run again with the additional arguments.
At this time you can verify that Graylog is ingesting data by going to “Inputs” and looking at the “Throughput/Metrics” section on the right.
At this time you can also start running searches by clicking on “Search” on the top left of the web page. Now that Graylog is ingesting logs, you can start working with the data being ingested. Keep in mind that this will only contain the logs since starting the docker container pointing it to Graylog. But any subsequent restarts of the container for updates or any other reason the container would stop will not result in log loss like it would before without redirecting to a separate file or another log source.
To start visualizing and quantifying the data beyond searching for logs, go to “Dashboards” via the top bar in the web page and click “Create new dashboard”
To create a widget for monitoring upload success/cancelled rates, use the following example.
On the left side, click the “+” icon or the arrow near the top of the left side to expand in order to create a widget. For this we will use the “Message Count” Predefined Aggregation. With the newly opened window, use the time dropdown to change from “Search in the last 5 minutes” to “Search in all messages” or whatever other timeframe you would like to observe the results from. Use the search query as below in the Search field, replacing $source_name with the the hostname of the system running the storagenode container:
source:$source_name AND Function:("uploaded"|"upload canceled")
Select “Visualization Type” → “Pie Chart”
Select “Rows” → “Function”
It should now show something similar to this:
Click Save at the bottom and now you have yourself the beginnings of a dashboard to monitor your upload success and cancelled rates in real time. To enable constant dashboard updates as new logs are ingested, click the “Not updating” dropdown menu in the top right side and select the frequency for updating the dashboard.
Don’t forget to click Save as well to save your dashboard whenever any changes are made.
In the default Graylog/Elasticsearch index set, 20M logs will be kept for each index and rotated 20 times before deleting data. This results in a setting of 400M log entries that Graylog will store. This can be reduced by going to “System” → “Indices” → “Default index set” and “Edit” on the left side.
In the newly opened window, at the bottom, change the “Max documents per index” in order to change how many lines of logs are kept in each index and change the “Max number of indices” to change how many indices (files) are kept. Multiplying these two together will tell you how many lines of logs will be stored before deletion occurs. Click “Save” once the settings have been updated to your preference.
There is a lot more that I am hoping to expand this by over time and hopefully be able to keep the extractors up to date if future storagenode updates change the logging format. Graylog will continue ingesting data even if the extractors stop matching incoming logs, but for some of the visualizations they will be impacted until the data is being indexed with updated extractors again.
Please let me know if you were successful in getting this set up as well as any improvements that can be made to this guide. Also as an ask to Storj staff if future updates change the logging format, that would be appreciated to know in the release notes so that extractors can be updated beforehand to keep indexing working properly as soon as a node is updated.
This was not me, all credits should go to @storjio68943 (the nick was in RocketChat), unfortunately I do not know her/his nickname on the forum.
Oh i also did a log thing… i like to think its pretty nice…
should work with whatever solutions you want to run, is just a clean way to getting the logs out of docker and in a orderly manner… i have checked compared thousands of lines of log and it doesn’t skip a beat, while still appending every minute… :smiley:
Fair enough! I had found your post when creating this in the suggested other topics and it helped to build out the extractor sections, just assumed you had built it. Was having a bit of a tough time figuring out the though process for GROK but comparing the commands you had linked to with the log messages that I had already ingested I was able to sort out the logic behind it and it ended up being a lot easier than expected.
In case anyone wants to build out more GROK extractors in Graylog, this site was invaluable for constructing the queries. Also the Logstash Github has a good reference here for the pattern types.
Thanks for posting this. I just got it up and running on a few nodes and so far so good!
Simple and fast enough.
Thanks for posting.
Do you happen to have any further updated GROK for the extrator?
Thanks,
-mike
With doing some filtering on the logs for the last little while it does look like some of my GROK filters are not properly parsing some edge cases that I was not seeing before. I will have to update my filters to catch them better but have not gotten around to building newer ones out yet. Thanks for running through this, always good to have someone confirm that I wasn’t totally out to lunch when putting this together.
Just wanted to update that i’ve been using graylog to track all my nodes now and I LOVE it. It’s so easy to configure and consolidates all the logs in one place.
I need better GROK and such. But so far so good.
Glad to hear it! If you can drop some logs (sanitized if you want) or at least the message types that aren’t getting picked up, that will help me to narrow down the scope of what is not being caught correctly.
TBH I haven’t used any of the GROK yet, am just now going to start playing with that. I was just happy to have all the logs searchable and in a centralized place.
Still running strong!
No worries. I haven’t had much time to put into this since first rolling it out and I am finding more and more logs slipping through the filters or getting incorrectly indexed, so it’ll come sooner rather than later. Looks like the changes to log content isn’t changing as much any more so it’ll be a good time coming up here to get things worked on a bit more.
Did you do any more work on this?
I was thinking about porting it to export to prometheus using the grok_exporter. Your work will make this a lot easier.
I haven’t improved it any but am still using it.
well my work resulted in
Thanks for this post, it inspired me to dig into the data a bit using Graylog to see where traffic was coming from. Kept me occupied over the holiday and resulted in this.
I wanted to test this too. But if configured log redirection and are unable to get rid of it.
--mount type=bind,source="/storagelogs/node2",destination=/app/logs
if i remove this docker run line i get the following error:
Error: open sink "/app/logs/node.log": open /app/logs/node.log: no such file or directory
Of course, because the folder /app/logs doesn’t exist inside the container. When you bind, it will be created automatically.
You may change the log location to /app/config/node.log, then it would be created in the data location.
Or do not use subfolders at all, and specify it as /app/node.log or even /var/log/storagenode.log, then the log will be created inside the container, but I do not know why do you need that.
I think if you use a Graylog, you may return the log.output option back to stdout or stderr, and the exporter should take it.
Yes i forgot, that i had to change the config.yaml. I changed it back to stdout.
Thank you
My method of shipping the logs was to add a GELF driver to my docker compose file:
 storagenode:
    container_name: storagenode
    logging:
      driver: "gelf"
      options:
        gelf-address: "udp://{insert your graylog address here}:12201"
Add the logging block, then docker compose down and docker compose up -d and you should start seeing logs (note that you have to set up a GELF input in Graylog as a target). You can also use the syslog driver, if that is more your style.
I put it in the Start command directly. I dont use docker compose (and didnt realy had the time to understand it)
    --log-driver gelf \
    --log-opt gelf-address=udp://192.168.2.17:5555 \
was enough for it to work
Now i have to take my time and Build a nice Dashboard (And add my Nodes from my other Location)
Hello,
may i ask how you got your map working? I cant really figure it out.
I made an extractor to get the ip:
but i cant figure out how to get the next one working. I tried pipeline with no luck
(this wont work)
What am i doing wrong? The fields for the geolocation wont apear.
I have set up the maxmind GeoIP Database.
Thank you in advance
I feel so stupid. The Lookup name is case sensitive. Thats why it didnt work.
I updated the pipeline rule to only show lat. and long.
now its working perfectly
