Loki Storj-Exporter-Logs and Storj-Logs dashboard
Hello all,
I’ve developed a dashboard that builds on the popular Storj-Exporter and Storj-Log-Exporter dashboards and uses Grafana Loki and Promtail as an alternative for scraping log files generating metrics. The primary incremental benefit this has over the existing toolchain is that log entries can be populated into Grafana dashboards, allowing to view logs for all nodes in one location.
Storj-Exporter-Logs dashboard:
Storj-Logs dashboard:
dashboard-logs
Motivation
I’ve been interested in exploring Grafana Loki with Promtail for log ingestion and metrics for a number of different services on my home server. Testing it out for Storj nodes seemed like a great way to get an understanding of how it works.
For Storj nodes, the main benefit is that a single Promtail listener can injest logs from multiple nodes and produce metrics that Prometheus can then scrape. Individual storj-log-exporter instances are not required.
Furthermore, once the logs are ultimately shipped to Loki, one can do LogQL queries against them in Grafana or using LogCLI. For example, to search for all ERROR log level entries:
Installation
Edit Storj Node Logging Parameters
Note: This dashboard requires the json log output from the storagenode service rather than the familiar console output. The log output looks different than the typical console output. However, common tools such as successrate.sh appear to be able parse JSON log files without issue.
An example log line item in JSON format is as follows:
{"L":"INFO","T":"2021-02-04T15:47:50.240Z","N":"piecestore","M":"download started","Piece ID":"H5MHLOAWQBOZKVABCF5SXROFFON2HSKZNSMFJSICIRDEFNRKZVBA","Satellite ID":"1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE","Action":"GET"}
Also, the Promtail configuration in this repo requires the Storj logs to be exported to a log file. An alternative Promtail configuration that uses the Loki Docker driver to ship logs directly is included in my full Storj docker-compose stack repo at fmoledina/docker-storj-config.
To set the log output to JSON encoding and to specify a log file, proceed with the following steps:
  1. Stop the storagenode.
  2. Edit the node config.yaml and set the following log.encoding and log.output parameters:
# configures log encoding. can either be 'console', 'json', or 'pretty'.
log.encoding: "json"
# can be stdout, stderr, or a filename
log.output: /mnt/storj/logs/storj01.log  # modify as required
Configure Promtail
Edit ./appconfig/promtail/config.yml for nodename and __path__ values, where __path__ is the log file configured in the Storj node config.yaml.
#### Edit the node labels below to suit your configuration #####
## Storj node logging to Loki + Prometheus metrics generation
## Requires log.encoding="json"
## Ensure nodename is the same as in Prometheus config for Storj-Exporter
- job_name: storj
  static_configs:
  - targets:
      - localhost
    labels:
      job: storj
      nodename: storj01   # Same as prometheus config
      __path__: /mnt/storj/logs/storj01.log
  # - targets:
  #     - localhost
  #   labels:
  #     job: storj
  #     nodename: storj02
  #     __path__: /mnt/storj/log/storj02.log
Configure Prometheus
Edit your Prometheus config to adjust Storj-Exporter and add Promtail scrape configs. Note that the label used is nodename rather than instance as in Storj-Exporter and storj-log-exporter instructions. This is to align with the corresponding nodename variable provided by Promtail for Storj node log files.
Add nodename to your existing job for each node:
  - job_name: 'storj-exporter'
    static_configs:
      - targets: ["storj01-exporter:9651"]  # adjust for your Storj-Exporter installation
        labels:
          nodename: "storj01"   # Same as promtail config
          instance: "storj01"   # Allows compatibility with existing Storj-Exporter-Dashboard
      # - targets: ["storj02-exporter:9651"]
      #   labels:
      #     nodename: "storj02"
      #     instance: "storj02"
Also add the Promtail metrics endpoint, where all the log metrics will be scraped from:
  - job_name: 'promtail'
    static_configs:
      - targets: ['promtail:9080']  # adjust for your docker configuration (i.e. localhost:9080 if forwarding ports)
Start Loki and Promtail
Start the service with the following docker run commands:
docker run -d --name promtail -p 9080:9080 -v /mnt/storj/logs:/mnt/storj/logs -v ./appconfig/promtail:/config -v /path/to/appdata/promtail:/data grafana/promtail:2.1.0 -config.file=/config/config.yml
docker run -d --name loki -p 3100:3100 -v ./appconfig/loki:/config -v /path/to/appdata/loki:/data grafana/loki:2.1.0 -config.file=/config/local-config.yaml
Alternatively, use the quick-start guide available at the Storj-Exporter-dashboard repo and add the services from the docker-compose.yml in this repo.
Start all the services in the combined docker-compose.yml:
docker-compose up -d
Add dashboard to Grafana
Add the dashboard from the files dashboard-exporter-logs.json and dashboard-logs.json in the same way as described in KevinK’s How-To monitor all nodes in your lan:
You’ll need to create the connection to the Loki datasource in Grafana and select that datasource along with Prometheus when loading these dashboards.
Notes
The Notes section from Storj-Log-Exporter are valid for the Promtail log metrics methodology presented in this repo.
Logging Limits
  • Loki has been configured with a 30 day log retention time. Adjust retention_period under table_manager in ./appconfig/loki/local-config.yaml if a different retention time is desired.
