Hey,
I’ve just inserted two 1TB SSDs into my Synology and therefore had to:
- Stop the Synology (and the node), plus installed the SSDs
→ I started it and the node started automatically - I stopped it as I had to create the SSD Cache
→ Then I restarted the node - After I checked the successrate.sh script I saw that my node is finally (in standard setting 7) rejecting some work while still could take more
========== UPLOAD ============ Successful: 14492 Rejected: 2317 Failed: 2240 Acceptance Rate: 86.216% Success Rate: 86.613%
- so I set storage2.max-concurrent-requests: 10
→ restart again
Before I got tons of files from 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs… now it’s almost nothing any more, mainly audit checks from 118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW
Is that because I rebooted 3 times or just bad luck?
Anyhow, how cool das this look?
Thanks
