My dashboard showing offline
My node for all satellites is currently offline
forwarded port alr
log
dashbaord
Did you try in chrome browser or with CTRL F5 ( refresh ) ?
alr still offline
Look at the uptime. It has reset from 28 minutes to 2, so I think it must be restarting.
The last contact time - it has never made contact?
Over to people with windows experience … but that browser looks like “edge” to me
i restart service 1 time that why it reset from 28 to 2 mins
have some connection but my node still offline
google chrome
Can you check if your identity folder has 6 files ?
have only 4
Your identity is not signed. Follow all the steps given in documentation to fix this.
https://documentation.storj.io/dependencies/identity
ok lemme generate new identity
rip lol
That’s lot of CPU usage.
1d later
best difficulty 35 xd
I got one once after less than a minute but another took 3 days - all luck
Not that I’ve got thousands of nodes, but I did some speed tests a while back
Why? You just needed to sign it.
You need to have only to sign it: https://documentation.storj.io/dependencies/identity#authorize-the-identity
But I think you already deleted a previous one.
ok i know rn why my identity have only 4 files
i forgot to Authorize the identity
