it just keeps restarting looks like the entrypoint command but i cant seem to see any logs or trace the error to see whats wrong? help greatly appreciated
When you run docker logs storagenode is there any output?
Sidenote, to do pre-formatted blocks of text in this forum (Discourse is the backend), you can place 3 backticks ``` above and below the text you want to blockquote.
no useful output really i see an error just above the usage output but i think its a red herring
Error: unknown shorthand flag: ‘e’ in -e
Usage:
storagenode run [flags]
…etc
The tail has just the global flags i dont think that is of any use.
Sounds like the run command is failing. Can you re-paste your run command between backticks as described? Sometimes the forum can strip useful clues about why your command isn’t working. Also, if you are using a text editor to create the run command, be sure to use notepad++, not MS word or something else that might change quotes, dashes, etc.
Edit the post but put ``` above and below (you can copy from my post). It will show in preview if it’s working. But I think I can already see some curly quotes in your commands which will need to be fixed.
Yes, definitely curly quotes where there shouldn’t be. You can see an example before your email address. I suggest copying the command from the docs into a linux friendly text editor (highly recommend notepad++), and redo your run command.
There should be quotes there, they are required, but your command has the wrong type. Compare the ones before and after your email. The first ones are the curly type.
What did you use to edit your command? The docs do not use curly quotes. They cause the command to fail. There are others, so you should really fix it. Chances are your email might not be properly recogized by the software if it wasn’t formatted properly. You could miss out on notification emails.
Sorry i had to wait 23hrs to post this because i just signed up (how rude :)). I removed all the quotes from the documentation, added my items and ran this …it seems to be working now thanks. note the quotes are also removed on all the storage and config locations. i have about 4 GB loaded into the 13TB container in the last 24 hrs.
