My first node is full, so I attached another HDD to my rig and setup a new identity, container, etcetc.
It’s running and getting vetted.
My only doubt is: what about the watchtower command? Do I have to simply issue a
docker run -d --restart=always --name watchtower -v /var/run/docker.sock:/var/run/docker.sock storjlabs/watchtower storagenode_2 watchtower --stop-timeout 300s --interval 21600
or is there something else? I’m not too familiar with watchtower and/or docker, so I don’t know if it can have conflicts by running twice on the same machine for the same type of container.
