No test traffic from Saltlake anymore?
Hi there,
I get almost no test data from SL since yesterday. Did I do something wrong? I have it on several nodes behind the same ip.
Finally a pause maybe my filewalkers will finish till next update now :rofl:
Hi @gs.gs, although it is news from a few weeks ago, maybe it is related to this:
By the way, I also did not receive much ingress (22.5 MB + 29 MB repair) from SL the last few days, but that could also be due to the fact my nodes are full:
Hello @gs.gs,
Welcome back!
Make sure that your node is not full (mine - are). Please check the disk usage, not the dashboard, because the dashboard may be way off due to errors in your logs.
I notice this too, and the disks are not full
It’s only Saltlake
Hi @Alexey I’ve several nodes (behind 1 ip) wich are not full according to the dashboards and on linux (df -h). All with the same issue.
It’s not an issue. Happened before… they just pause sometimes on saltlake
Hi, Do you mean they pause the traffic to some nodes and not all? Do you still have traffic from Saltlake?
No, they pause or slow down test data (to all nodes). No test data here since yesterday either. It’s not a problem.
Looks like test data is flowing again. But I never expect it to be continuous.
Yep, it is starting up again on my nodes as well.
this should be according to the plans:
But granted, there could be issues with the load-test facility.
Please, do not panic :slight_smile:
