@RandallStevens If you migrated a worked node to the Linux, you must not generate a new identity and perform a setup step, otherwise you will destroy your old node, what you seems almost did. And this is good, that it cannot start.
I hope that you at least did not generate a new identity, otherwise you need to copy your previous identity from the Windows PC again.
Please also make sure that you migrated all data to the /mnt/STORJ/storagenode/data/storage/ (note the subdirectory storage, this is important!).
If you migrated to the /mnt/STORJ/storagenode/data/ path, not to the /mnt/STORJ/storagenode/data/storage/, then you need to move all data from /mnt/STORJ/storagenode/data/ to /mnt/STORJ/storagenode/data/storage/.
You must never execute the docker run command with SETUP=true for existing node!
In your docker run command you will use /mnt/STORJ/storagenode/data (note here the storage subdirectory must absent).
Please provide the last 20 lines from your logs (text please, not a screenshot).
To prettify the look, place logs lines here between two new lines with three backticks, like this
