that worked…
> --name storagenode storjlabs/storagenode:latest
27965d6a84f5d5a3c3728d8
dashboard still not loading.
Here is the log file
2022-10-30 14:00:11,401 INFO exited: storagenode (exit status 1; not expected)
2022-10-30 14:00:13,405 INFO spawned: 'storagenode' with pid 72
2022-10-30T14:00:13.437Z INFO Anonymized tracing enabled {"Process": "storagenode"}
2022-10-30T14:00:13.449Z INFO Operator email {"Process": "storagenode", "Address": "(deleted)"}
2022-10-30T14:00:13.449Z INFO Operator wallet {"Process": "storagenode", "Address": "(deleted)"}
Error: trust: open config/trust-cache.json: permission denied
2022-10-30 14:00:13,504 INFO exited: storagenode (exit status 1; not expected)
“permission denied”
ls -la /mnt/STORJ/storagenode/data
total 44
drwxrwxrwx 4 randall randall 4096 Oct 30 09:31 .
drwxrwxr-x 5 randall randall 4096 Oct 16 19:52 ..
drwx------ 4 randall randall 4096 Oct 29 16:17 orders
-rw------- 1 randall randall 32768 Oct 30 10:14 revocations.db
drwx------ 7 randall randall 4096 Oct 30 10:14 storage
-rw------- 1 root root 1374 Oct 30 09:31 trust-cache.json
you have corrected:
–mount type=bind,source=“/mnt/STORJ/storagenode/data/storage”,destination=/app/config \
I just made the change.
Stopped the node and removed the container:
sudo docker stop -t 300 storagenode
AND THEN…
sudo docker rm storagenode
I then reran the docker command with the changes you just gave…
The dashboard still will not load
latest log file
Error: Error starting master database on storagenode: group:
--- stat config/storage/blobs: no such file or directory
--- stat config/storage/temp: no such file or directory
--- stat config/storage/garbage: no such file or directory
--- stat config/storage/trash: no such file or directory
2022-10-30 14:19:46,126 INFO exited: storagenode (exit status 1; not expected)
2022-10-30 14:19:47,127 INFO gave up: storagenode entered FATAL state, too many start retries too quickly
2022-10-30 14:19:48,129 WARN received SIGQUIT indicating exit request
2022-10-30 14:19:48,129 INFO waiting for processes-exit-eventlistener, storagenode-updater to die
2022-10-30T14:19:48.129Z INFO Got a signal from the OS: "terminated" {"Process": "storagenode-updater"}
2022-10-30 14:19:48,131 INFO stopped: storagenode-updater (exit status 0)
2022-10-30 14:19:49,132 INFO stopped: processes-exit-eventlistener (terminated by SIGTERM)
2022-10-30 14:19:49,878 INFO RPC interface 'supervisor' initialized
2022-10-30 14:19:49,878 INFO supervisord started with pid 1
then:
ls -la /mnt/STORJ/storagenode/data/storage
otal 51532
drwx------ 7 randall randall 4096 Oct 30 10:16 .
drwxrwxrwx 4 randall randall 4096 Oct 30 09:31 ..
-rwxrwxrwx 1 randall randall 37732352 Oct 30 09:39 bandwidth.db
drwxrwxrwx 8 randall randall 4096 Apr 26 2021 blobs
-rw------- 1 randall randall 9705 Oct 26 21:45 config.yaml
drwxrwxrwx 2 randall randall 4096 Oct 30 09:32 garbage
-rwxrwxrwx 1 randall randall 77824 Oct 30 09:39 heldamount.db
-rwxrwxrwx 1 randall randall 16384 Oct 30 09:39 info.db
-rwxrwxrwx 1 randall randall 24576 Oct 30 09:39 notifications.db
drwx------ 4 randall randall 4096 Oct 26 21:52 orders
-rwxrwxrwx 1 randall randall 32768 Oct 30 09:39 orders.db
-rwxrwxrwx 1 randall randall 13516800 Oct 30 09:39 piece_expiration.db
-rwxrwxrwx 1 randall randall 24576 Oct 30 09:39 pieceinfo.db
-rwxrwxrwx 1 randall randall 24576 Oct 30 09:39 piece_spaced_used.db
-rwxrwxrwx 1 randall randall 24576 Oct 30 09:39 pricing.db
-rwxrwxrwx 1 randall randall 36864 Oct 30 09:39 reputation.db
-rw------- 1 randall randall 32768 Oct 29 16:10 revocations.db
-rwxrwxrwx 1 randall randall 32768 Oct 30 09:39 satellites.db
-rwxrwxrwx 1 randall randall 24576 Oct 30 09:39 secret.db
-rwxrwxrwx 1 randall randall 32 Apr 24 2021 storage-dir-verification
-rwxrwxrwx 1 randall randall 1032192 Oct 30 09:39 storage_usage.db
drwxrwxrwx 2 randall randall 69632 Oct 23 23:25 temp
drwxrwxrwx 8 randall randall 4096 Apr 27 2021 trash
-rw------- 1 randall randall 1374 Oct 29 16:10 trust-cache.json
-rwxrwxrwx 1 randall randall 20480 Oct 30 09:39 used_serial.db
Stop the container, remove it, log out of the system, log in, start the container…
I have to leave, @Alexey look at these data paths and permissions
It is the path that is supposed to be:
--mount type=bind,source="/mnt/STORJ/storagenode/data",destination=/app/config \
Before doing so, you need to swap the rights for the file:
sudo chown randall:randall /mnt/STORJ/storagenode/data/trust-cache.json
Because:
and
Okay. I ran “sudo Chown” and fixed the command line back to how it should be.
I’m getting the dashboard again but it’s saying offline
Here is the log
2022-10-30T18:37:24.613Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 7, "error": "ping satellite: failed to dial storage node (ID: 12q9SBbHrkRKDECe86XNTRq1YSt99f4RZqFXZZHsiYuUZpEWdy5) at address (deleted):28967: rpc: tcp connector failed: rpc: dial tcp 73.144.175.37:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 12q9SBbHrkRKDECe86XNTRq1YSt99f4RZqFXZZHsiYuUZpEWdy5) at address (deleted):28967: rpc: tcp connector failed: rpc: dial tcp 73.144.175.37:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-10-30T18:37:27.537Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "attempts": 7, "error": "ping satellite: failed to dial storage node (ID: 12q9SBbHrkRKDECe86XNTRq1YSt99f4RZqFXZZHsiYuUZpEWdy5) at address (deleted):28967: rpc: tcp connector failed: rpc: dial tcp 73.144.175.37:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 12q9SBbHrkRKDECe86XNTRq1YSt99f4RZqFXZZHsiYuUZpEWdy5) at address (deleted):28967: rpc: tcp connector failed: rpc: dial tcp 73.144.175.37:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
Besides, you don’t have
config.yaml
in the folder
and it must be there
(You have it in /mnt/STORJ/storagenode/data/storage but I don’t know if the correct one…)
Well I’ll be damned…
That worked! We are online and OK!!!
Thank you kindly for your patience and assistance.
I was very pleased to hear this, good luck with the running of SN, regards
I have a similar issue:
2023-04-28T12:57:15.972Z WARN piecestore:monitor Disk space is less than requested. Allocated space is {"Process": "storagenode", "bytes": 115851190272}
2023-04-28T12:57:15.972Z ERROR piecestore:monitor Total disk space is less than required minimum {"Process": "storagenode", "bytes": 500000000000}
2023-04-28T12:57:15.972Z ERROR services unexpected shutdown of a runner {"Process": "storagenode", "name": "piecestore:monitor", "error": "piecestore monitor: disk space requirement not met", "errorVerbose": "piecestore monitor: disk space requirement not met\n\tstorj.io/storj/storagenode/monitor.(*Service).Run:127\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
2023-04-28T12:57:15.972Z INFO pieces:trash emptying trash started {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2023-04-28T12:57:15.972Z ERROR nodestats:cache Get pricing-model/join date failed {"Process": "storagenode", "error": "context canceled"}
2023-04-28T12:57:15.972Z ERROR collector error during collecting pieces: {"Process": "storagenode", "error": "pieceexpirationdb: context canceled", "errorVerbose": "pieceexpirationdb: context canceled\n\tstorj.io/storj/storagenode/storagenodedb.(*pieceExpirationDB).GetExpired:39\n\tstorj.io/storj/storagenode/pieces.(*Store).GetExpired:556\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:88\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:57\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/storj/storagenode/collector.(*Service).Run:53\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
2023-04-28T12:57:15.973Z ERROR piecestore:cache error during init space usage db: {"Process": "storagenode", "error": "piece space used: context canceled", "errorVerbose": "piece space used: context canceled\n\tstorj.io/storj/storagenode/storagenodedb.(*pieceSpaceUsedDB).Init:73\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:81\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
2023-04-28T12:57:15.973Z ERROR gracefulexit:blobscleaner couldn't receive satellite's GE status {"Process": "storagenode", "error": "context canceled"}
2023-04-28T12:57:15.973Z ERROR bandwidth Could not rollup bandwidth usage {"Process": "storagenode", "error": "sql: transaction has already been committed or rolled back"}
2023-04-28T12:57:15.973Z ERROR gracefulexit:chore error retrieving satellites. {"Process": "storagenode", "error": "satellitesdb: context canceled", "errorVerbose": "satellitesdb: context canceled\n\tstorj.io/storj/storagenode/storagenodedb.(*satellitesDB).ListGracefulExits:149\n\tstorj.io/storj/storagenode/gracefulexit.(*Service).ListPendingExits:59\n\tstorj.io/storj/storagenode/gracefulexit.(*Chore).AddMissing:58\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/storj/storagenode/gracefulexit.(*Chore).Run:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
Error: piecestore monitor: disk space requirement not met
2023-04-28 12:57:16,210 INFO stopped: storagenode (exit status 1)
2023-04-28 12:57:16,211 INFO stopped: processes-exit-eventlistener (terminated by SIGTERM)
If I am running a df --si I can’t see my mount folder of 11TB
df --si
Filesystem Size Used Avail Use% Mounted on
/dev/root 126G 4.6G 116G 4% /
devtmpfs 3.9G 0 3.9G 0% /dev
tmpfs 4.1G 0 4.1G 0% /dev/shm
tmpfs 1.7G 1.5M 1.7G 1% /run
tmpfs 5.3M 4.1k 5.3M 1% /run/lock
/dev/mmcblk0p1 268M 33M 236M 13% /boot
tmpfs 820M 21k 820M 1% /run/user/1000
I should see something like this
lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sdb 8:16 0 4.5T 0 disk
└─sdb1 8:17 0 4.5T 0 part
└─storj_crypto-storj_lv 254:0 0 10T 0 lvm
sdc 8:32 0 931.5G 0 disk
└─sdc1 8:33 0 931.5G 0 part
mmcblk0 179:0 0 119.1G 0 disk
├─mmcblk0p1 179:1 0 256M 0 part /boot
└─mmcblk0p2 179:2 0 118.8G 0 part /
You need to create a static mount in /etc/fstab.
Also, did you create a logical volume spanning 2 drives? You shouldn’t do this. If one disk fails all data from both disks will be gone. You better should setup 1 node per disk.
