You don’t need to post everything, just scan through it, but I’m afraid they will all be missing file errors. It seems you’ve lost data, which sucks. Not much you can do about that now I’m afraid.
Can you look to see if the files are there just to be sure. I see the file path is no longer displayed in these logs. You can find them by looking in the blobs folder in the corresponding folder for the mentioned satellite in the following list
thank you for that information, i think it will be helpful for everyone.
I found few like this:
C:\Program Files\Storj\Storage Node\storagenode.log:4985:2021-07-06T18:47:09.866+0300 ERROR piecestore download failed
{“Piece ID”: “GQNCZE255MWYA7KX3FUGMAHTJVMNU4DA2UW3TIXLIZKSCNH3YBOA”, “Satellite ID”:
“1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET_REPAIR”, “error”: “file does not exist”,
“errorVerbose”: “file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:74\n\tstorj.io/storj/storagenode/piecestore.
(*Endpoint).Download:508\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:217\n\tstorj.io/drpc/drpcmux.(*Mu
x).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:58\n\tstorj.io/drpc/drpcserver.(*Server).handleR
PC:111\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:62\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:99\n\tstorj.
io/drpc/drpcctx.(*Tracker).track:51”}
I searched for a file with name “NCZE255MWYA7KX3FUGMAHTJVMNU4DA2UW3TIXLIZKSCNH3YBOA” in the folder “F:\StorJ\blobs\pmw6tvzmf2jv6giyybmmvl4o2ahqlaldsaeha4yx74n5aaaaaaaa\gq”, but couldn’t find it. Am I following you instructions correctly?
I tried searching for few more files like this and couldn’t find any of them. So … did I lose them few weeks ago, when I had hdd issues? Can this somehow be checked? Because I checked my hdds yesterday and they did not have any bad sectors. My question, more or less is, What are the reasons to get such errors and maybe slight drop in the audits?
I noticed that this folder is 245GB. Now that I am discqualified from this node … what happens with the data? Should I delete this folder within the blobs folder?
That looks correct, but you can always verify by trying to find another piece ID from the log for a successful transfer.
There isn’t really a way to find out which pieces you should have. It seems you are failing relatively few audits, so your node will likely survive on other satellites.
I don’t like recommending you remove data, so I won’t. But I believe the satellite doesn’t delete data on your node once it has been disqualified. Maybe a Storjling could chime in to give advise on what to do in such cases.
