Node ID mismatched problem
Hi guys, I was trying to retrieve the node id using identity command:
 identity certificate-authority id --ca.cert-path identity.cert
2025-12-18T16:27:30Z    INFO    Anonymized tracing enabled
base58-check node ID:   1AvWAduWsFcwJC5pkVt9q934SYcpKVYigS4s9enggw2QTBGWgZ
hex node ID:            3141765741647557734663774a4335706b56743971393334535963704b5659696753347339656e676777325154424757675a
node ID bytes:          [22 135 184 253 222 210 32 194 167 19 191 71 0 254 50 217 208 194 219 142 119 217 57 128 205 180 220 211 139 229 82 0]
difficulty:             9
but the node ID is different from the actual node ID I see for my node
19yKczzNjwdCUppd1j4e2RZt6sU1qyYoxBsvMD88oxVkANYkEW
why is that?
Because you specified a wrong certificate, you need to check ca.cert, not identity.cert.
Please, specify the full path to the CA certificate:
I don’t remember how I created the identity but now there’s only 2 files in the identity folder: identity.key and identity.cert?
I found it. Thank you!
