i also checked now
you are write
but on router setting also
and widows firewall both incoming and outging port ok
i also checked now
you are write
Those all look correct, in the router and Windows Firewall. Are you running the node on docker or native Windows installer?
native window installer
Please, clear the field “External IP Addr” in your port forwarding rule and delete duplicated rule
Please, disable DMZ
Search on your router the page with WAN IP (I think it’s on Status page) and compare this IP with IP on yougetsignal, they must match, otherwise port forwarding will not work.
both ip different
what we will do now
