i am new at node install windows gui
port also open
but node offfline
port also open
but node offfline
Hi @Vishal,
You’ve not given much information for us to help…
We need to know the log files data - https://documentation.storj.io/resources/faq/check-logs
Have you tested the open port? Open Port Check Tool - Test Port Forwarding on Your Router
please help i am new setup using windows gui
port also open
but still offline
We can help if you do these steps:
PS C:\Users\Arshi Technologies 2> Get-Content “$env:ProgramFiles/Storj/Storage Node/storagenode.log” -Tail 20 -Wait
2021-06-15T23:10:24.284+0530 ERROR contact:service ping satellite failed {“Satellite ID”: “12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo”, “attempts”: 5, “error”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 205.254.164.190:28967: i/o timeout”, “errorVerbose”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 205.254.164.190:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-06-15T23:10:37.347+0530 ERROR contact:service ping satellite failed {“Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “attempts”: 6, “error”: “ping satellite: check-in ratelimit: node rate limited by id”, “errorVerbose”: “ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-06-15T23:10:41.142+0530 ERROR contact:service ping satellite failed {“Satellite ID”: “12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo”, “attempts”: 6, “error”: “ping satellite: check-in ratelimit: node rate limited by id”, “errorVerbose”: “ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-06-15T23:10:41.240+0530 ERROR contact:service ping satellite failed {“Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “attempts”: 11, “error”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 205.254.164.190:28967: connect: no route to host”, “errorVerbose”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 205.254.164.190:28967: connect: no route to host\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-06-15T23:11:10.180+0530 ERROR contact:service ping satellite failed {“Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “attempts”: 7, “error”: “ping satellite: check-in ratelimit: node rate limited by id”, “errorVerbose”: “ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-06-15T23:11:13.871+0530 ERROR contact:service ping satellite failed {“Satellite ID”: “12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo”, “attempts”: 7, “error”: “ping satellite: check-in ratelimit: node rate limited by id”, “errorVerbose”: “ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-06-15T23:11:24.709+0530 ERROR contact:service ping satellite failed {“Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “attempts”: 11, “error”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 205.254.164.190:28967: i/o timeout”, “errorVerbose”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 205.254.164.190:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-06-15T23:12:14.993+0530 ERROR contact:service ping satellite failed {“Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “attempts”: 8, “error”: “ping satellite: check-in ratelimit: node rate limited by id”, “errorVerbose”: “ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-06-15T23:12:38.782+0530 ERROR contact:service ping satellite failed {“Satellite ID”: “12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo”, “attempts”: 8, “error”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 205.254.164.190:28967: i/o timeout”, “errorVerbose”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 205.254.164.190:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-06-15T23:13:36.570+0530 ERROR contact:service ping satellite failed {“Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “attempts”: 10, “error”: “ping satellite: check-in ratelimit: node rate limited by id”, “errorVerbose”: “ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-06-15T23:14:43.855+0530 ERROR contact:service ping satellite failed {“Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “attempts”: 9, “error”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 205.254.164.190:28967: i/o timeout”, “errorVerbose”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 205.254.164.190:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-06-15T23:14:47.617+0530 ERROR contact:service ping satellite failed {“Satellite ID”: “12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo”, “attempts”: 9, “error”: “ping satellite: check-in ratelimit: node rate limited by id”, “errorVerbose”: “ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-06-21T15:25:04.411+0530 INFO bandwidth Performing bandwidth usage rollups
2021-06-21T15:25:05.622+0530 INFO trust Scheduling next refresh {“after”: “3h56m8.815188506s”}
2021-06-21T15:25:06.047+0530 ERROR contact:service ping satellite failed {“Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “attempts”: 12, “error”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 205.254.164.190:28967: connect: no route to host”, “errorVerbose”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 205.254.164.190:28967: connect: no route to host\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-06-21T15:25:25.108+0530 ERROR contact:service ping satellite failed {“Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “attempts”: 10, “error”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 205.254.164.190:28967: i/o timeout”, “errorVerbose”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 205.254.164.190:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-06-21T15:25:25.237+0530 ERROR contact:service ping satellite failed {“Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “attempts”: 12, “error”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 205.254.164.190:28967: i/o timeout”, “errorVerbose”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 205.254.164.190:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-06-21T15:25:25.265+0530 ERROR contact:service ping satellite failed {“Satellite ID”: “12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo”, “attempts”: 10, “error”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 205.254.164.190:28967: i/o timeout”, “errorVerbose”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 205.254.164.190:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-06-21T15:25:25.328+0530 ERROR contact:service ping satellite failed {“Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “attempts”: 12, “error”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 205.254.164.190:28967: i/o timeout”, “errorVerbose”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 205.254.164.190:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-06-21T15:25:25.350+0530 ERROR contact:service ping satellite failed {“Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “attempts”: 11, “error”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 205.254.164.190:28967: i/o timeout”, “errorVerbose”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 205.254.164.190:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-06-21T15:28:58.803+0530 INFO Interrogate request received.
2021-06-15T23:09:51.618+0530 ERROR contact:service ping satellite failed {“Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “attempts”: 4, “error”: “ping satellite: check-in ratelimit: node rate limited by id”, “errorVerbose”: “ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-06-15T23:09:55.498+0530 ERROR contact:service ping satellite failed {“Satellite ID”: “12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo”, “attempts”: 4, “error”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 205.254.164.190:28967: i/o timeout”, “errorVerbose”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 205.254.164.190:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-06-15T23:10:20.621+0530 ERROR contact:service ping satellite failed {“Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “attempts”: 5, “error”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 205.254.164.190:28967: i/o timeout”, “errorVerbose”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 205.254.164.190:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
I would recommend replacing the DDNS name with the WAN IP for testing; you can do this in the config.yaml file and then restart the node. The name resolution doesn’t seem to be working correctly.
wan ip means
external ip
or
server ip (192.168.1.x))
still offilne i changed to external ip and port
Did you restart the node after the external IP change? What is in the log files since the change?
i restarted bou same error
2021-06-21T15:34:18.258+0530 ERROR contact:service ping satellite failed {“Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “attempts”: 11, “error”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout”, “errorVerbose”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-06-21T15:34:18.348+0530 ERROR contact:service ping satellite failed {“Satellite ID”: “12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo”, “attempts”: 11, “error”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout”, “errorVerbose”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-06-21T15:42:50.464+0530 ERROR contact:service ping satellite failed {“Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “attempts”: 12, “error”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout”, “errorVerbose”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-06-21T15:51:43.335+0530 ERROR contact:service ping satellite failed {“Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “attempts”: 12, “error”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout”, “errorVerbose”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-06-21T15:51:43.984+0530 ERROR contact:service ping satellite failed {“Satellite ID”: “12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo”, “attempts”: 12, “error”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout”, “errorVerbose”: “ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishaldishanode.ddns.net:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
The DDNS name is still showing, so it doesn’t look like the storagenode software is restarted. Although DDNS resolution is now showing the correct external IP. Please restart the whole computer.
ok sir
i restart now
| 2021-06-21T16:00:52.776+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE, attempts: 2, error: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout, errorVerbose: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
| 2021-06-21T16:00:52.797+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB, attempts: 2, error: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout, errorVerbose: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
| 2021-06-21T16:00:53.411+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo, attempts: 2, error: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout, errorVerbose: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
| 2021-06-21T16:00:53.420+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S, attempts: 2, error: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout, errorVerbose: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
| 2021-06-21T16:00:53.912+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, attempts: 2, error: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout, errorVerbose: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
| 2021-06-21T16:00:54.120+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs, attempts: 2, error: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout, errorVerbose: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
| 2021-06-21T16:00:56.285+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S, attempts: 3, error: ping satellite: check-in ratelimit: node rate limited by id, errorVerbose: ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
| 2021-06-21T16:01:15.436+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB, attempts: 3, error: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout, errorVerbose: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
| 2021-06-21T16:01:15.686+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE, attempts: 3, error: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout, errorVerbose: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
| 2021-06-21T16:01:16.509+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, attempts: 3, error: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout, errorVerbose: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
| 2021-06-21T16:01:16.550+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo, attempts: 3, error: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout, errorVerbose: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
| 2021-06-21T16:01:16.743+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs, attempts: 3, error: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout, errorVerbose: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
| 2021-06-21T16:01:21.320+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S, attempts: 4, error: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout, errorVerbose: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
| 2021-06-21T16:01:40.279+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB, attempts: 4, error: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout, errorVerbose: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
| 2021-06-21T16:01:40.547+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE, attempts: 4, error: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout, errorVerbose: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
| 2021-06-21T16:01:41.446+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs, attempts: 4, error: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout, errorVerbose: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
| 2021-06-21T16:01:41.473+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo, attempts: 4, error: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout, errorVerbose: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
| 2021-06-21T16:01:42.266+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, attempts: 4, error: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout, errorVerbose: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
| 2021-06-21T16:01:48.923+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB, attempts: 5, error: ping satellite: check-in ratelimit: node rate limited by id, errorVerbose: ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
| 2021-06-21T16:01:49.332+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE, attempts: 5, error: ping satellite: check-in ratelimit: node rate limited by id, errorVerbose: ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
| 2021-06-21T16:01:50.560+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S, attempts: 5, error: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout, errorVerbose: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address 103.211.18.36:28967: rpc: dial tcp 103.211.18.36:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
I did some more investigating as the open port on 28967 is not storagenode software. It looks to be something else. Please double check your port forwarding rule(s) and also the local Windows Firewall which should allow both incoming and outgoing traffic on that port - Pingdom
