Hi @Vishal,
I am concerned by this WAN IP, it shows some kind of CGNAT is involved:
The CGNAT means your IP from the DDNS resolution isn’t actually yours, or your routers.
You will need to speak to your internet provider and ask about fixed public IP address, or use a VPN service to provide a public IP address.
That is outside the scope of this forum, but you can click the ‘Register’ button on their homepage.
Change Proto to ‘tcp’. Click ‘Generate’.
Use the list on the right - Install OpenVPN software, Download configuration file (after generate), create the rule, start OpenVPN software with config file.
I’ve not done this before, so I don’t know the answers. My guesses would be:
Port on your PC - 28967
Click ‘Create’.
Edit config.yaml on your PC…
contact.external-address: vishalsgang-3561.portmap.host:35614
server.address: :28967
Restart the storagenode service.
You can leave that blank.
2021-06-22T19:42:21.529+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs, attempts: 4, error: ping satellite: check-in ratelimit: node rate limited by id, errorVerbose: ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
2021-06-22T19:42:21.537+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE, attempts: 4, error: ping satellite: check-in ratelimit: node rate limited by id, errorVerbose: ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
2021-06-22T19:42:21.757+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, attempts: 4, error: ping satellite: check-in ratelimit: node rate limited by id, errorVerbose: ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
2021-06-22T19:42:21.982+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo, attempts: 4, error: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishalsgarg-35614.portmap.host:35614: rpc: dial tcp 193.161.193.99:35614: connect: connection refused, errorVerbose: ping satellite: failed to dial storage node (ID: 12WtL4sQ9s3MLrPrV7RbziH184fSog8xeKCD7xayxKtoHeXk1Ge) at address vishalsgarg-35614.portmap.host:35614: rpc: dial tcp 193.161.193.99:35614: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
2021-06-22T19:42:23.190+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S, attempts: 4, error: ping satellite: check-in ratelimit: node rate limited by id, errorVerbose: ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
2021-06-22T19:42:29.746+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB, attempts: 5, error: ping satellite: check-in ratelimit: node rate limited by id, errorVerbose: ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
2021-06-22T19:42:30.067+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs, attempts: 5, error: ping satellite: check-in ratelimit: node rate limited by id, errorVerbose: ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
2021-06-22T19:42:30.271+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE, attempts: 5, error: ping satellite: check-in ratelimit: node rate limited by id, errorVerbose: ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
2021-06-22T19:42:30.301+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, attempts: 5, error: ping satellite: check-in ratelimit: node rate limited by id, errorVerbose: ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
2021-06-22T19:42:30.726+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo, attempts: 5, error: ping satellite: check-in ratelimit: node rate limited by id, errorVerbose: ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
2021-06-22T19:42:32.027+0530 | ERROR | contact:service | ping satellite failed | {Satellite ID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S, attempts: 5, error: ping satellite: check-in ratelimit: node rate limited by id, errorVerbose: ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57} |
